Elec star kit for predator engine...
PA
https://m.harborfreight.com/8-hp-301cc-ohv-horizontal-shaft-gas-engine-epa-62554.html?utm_referrer=direct%2Fnot%20provided
Is electric start kit available anywhere?
I like the power start but, predator doesn't look like the have that on their new engines.
Thanks
Only you can prevent forest fires.
SmokeyBear
HF sells a set off 1/4" hex drive adapters : 1/2, 3/8 and 1/4 drives for 2.99. The Farm project guy was my inspiration. OTOH , the 212 cc Predator starts very easily using the recoil.
In case your worried about how hard this engine is to start.
I put the 8hp on this snowblower, this will be it's 4th winter, usually starts first pull, 2nd pull at most.
I have the same exact 301cc engine in my old Bolens 1250
Starts first pull, every time
