I'll be changing the water pump on my F250 in sig this weekend, along with new coolant, thermostat, thermostat housing and hoses. I work at Napa so I am able to use PartsPro along with a Mitchell catalog to look up torque specs. It says the specs for the water pump and waterpump outlet are 15 ft lbs, also the thermostat housing is 15 ft lbs. Most of the Powerstroke forums say 18 ft lbs for the waterpump and outlet. I'd like to know the proper specs.
Also, I'm considering buying a Dieselsite thermostat housing as pictured below, as you can see in the pic, the max torque recommended is 100 inch pounds. If I go with a factory stamped steel housing, should I torque it to 100 inch pounds or 15 ft lbs?
https://www.dieselsite.com/blackbilletaluminumthermostathousing.aspx
