Originally Posted by dave1251
Originally Posted by tony1679
Originally Posted by Snagglefoot
The pre-2014 AFM version had the potential to be very troublesome.
Absolutely correct.
Originally Posted by Phishin
This is why I bought a truck with a 6.0L
No AFM on these old work horses
Smart choice.
Like a lot of "problems" BITOG members blow it out of proportion.
Oh, do elaborate please!
Originally Posted by LeakySeals
I belong to a few Tahoe/Yukon/Escalade FB enthusiast pages and AFM related engine failures are maybe the the biggest complaint.
Especially the 07-09 5.3L. Lesser for the 6.2, but still exists. Over time during AFM operation a lifter gets stuck, collapses. When it does, the shell rubs on the cam lobe. Wears the lobe down. The result is engine teardown for new lifters, new cam.
A tune to delete or a device that disables AFM is very popular. There is also a TSB for a valve cover upgrade that helps. The valve cover has an integrated PCV valve. The PCV baffle hole in the cover was too small resulting in too much pressure, excess buildup of blowby. Further inflaming the lifter issues.
The difference using AFM is maybe 2 MPG as reported by many owners. Will things be different in 2019? Who knows. i hope so. Until then I'm sticking with my 6.0 LQ9
Preach!
My 5.3L is 99% the same engine. In my case, my mpgs went
UP by 2 by
disabling AFM. Smart decision on the LQ9.
Originally Posted by TiredTrucker
Ditto!! While I am not against technology, there can be times when
it is used as a solution in search of a problem.
And I am just an old Cavalry Sergeant.... I expect everyone to pack the gear. If I pay for 8 cylinders that is because I wanted 8 cylinders and I expect them all to carry the load. None of them taking union or government inspired smoke breaks while the others do the work.
Bingo! And the main problem is the EPA mandates on fuel economy. GM just can't figure out how to easily meet it, and comes up with stupid designs like this while trying.
at the smoke breaks. In my experience, those cylinders literally smoked out the tail pipes before I disabled it.
Really do not need to eliberate the failure rate of the AFM is less than 1%. Yet the GM 5.3 is another example of internet over amplification of a very minor issue. A Volkswagen is much more likely to suffer engine issues then any GM 5.3.
This. And GM sells over 40,000 units a month Silverado/Sierra combined. And they made engine changes at the 2014 model year to correct AFM issues. GM is selling plenty of trucks at $45,000.00 to $60,000.00 (plus) a pop.
