Hi.
Gasoline price was increased last year in my country.
It is 2x more expensive than LPG. There is generally heavy traffic in the city. So the consumption is as much as 17L-18L/100km
According to what i found after google searches,
LPG has less calourific value, which means reduced power and increased fuel consumption.
But it also has higher octane rating, which let engine use it as a premium fuel, so more advanced ignition timing, more thermal efficiency.
So in theory, it may compensate for its lower calourific value at some level.
But, since gasoline is liquid, when it evaporates, it cools down the cylinders. But "standart" LPG conversions inject LPG as a gas to cylinders, means its higher octane rating wouldn't be as effective as expected.
Car's engine is M54, with 10.8:1 compression ratio.
If any of you has used it, would you recommend it ? How much difference is there in fuel consumption ?
