I have found that a good mounting prolongs the life of mower batteries. Often the original one is poor. I have used plumbers strap and a few extra screws to make a more secure mounting. A thin stick on rubber pad under the battery also helps. And a maintainer.
As far as I know, any mower that has an electric PTO clutch has a voltage regulator. Because of the safety requirement to disengage blades in reverse (easily defeated I might add) every riding mower since 2004 has electric PTO so they also have regulator.
