CV Joint Leaking Grease
by 92saturnsl2 - 08/22/19 10:20 PM
Craftsman 6 pc. Screwdriver Set $12.14
by Warstud - 08/22/19 09:32 PM
Got My ATF Replaced.
by Mr_Luke - 08/22/19 09:20 PM
Wht do people with labor intensive jobs lay on their back?
by motor_oil_madman - 08/22/19 09:14 PM
Date code 5 Q Chevron location?
by Onetor - 08/22/19 08:06 PM
Confused, what oil to use?
by BelAir - 08/22/19 08:00 PM
2015 KIA optima turbo Coolant Flush
by Grambo - 08/22/19 07:52 PM
Motul 300V -- oops
by xr650boy - 08/22/19 06:35 PM
Evolution of Garbage Trucks...joke thread
by GumbyJarvis - 08/22/19 05:57 PM
What is this Oil's Application?
by MolaKule - 08/22/19 05:19 PM
Ford 2.5L Engine and 6F35 Transmission
by drh214 - 08/22/19 04:57 PM
Fram XG7317 vs XG3593A
by gamefoo21 - 08/22/19 03:59 PM
Carquest premium 85334
by SlavaB - 08/22/19 03:47 PM
Oil for a Ford 2.8 L Cologne V6
by ford4wd08 - 08/22/19 03:46 PM
Good Question?🤔
by Mad_Hatter - 08/22/19 01:40 PM
Autozone misinformation?
by NavyVet88 - 08/22/19 11:23 AM
Did I mess up getting a civic that sat?
by Kurtatron - 08/22/19 10:48 AM
What are these two things in the bumper?
by atikovi - 08/22/19 09:48 AM
Amsoil Metal Protector
by Snagglefoot - 08/22/19 09:07 AM
PTL, vdubw, NJ01MGM, Antiquity, tundraotto
69034 Registered Users
26 registered members (Deontologist, carlprop, e55amgbenz007, edyvw, clinebarger, 4 invisible), 881 guests, and 20 spiders.
Topics293,664
Posts5,044,641
Members69,034
Most Online3,532
Jul 30th, 2019
Yellow plus red #4817880 07/19/18 07:54 AM
W
wsteveg Offline OP
W
I have Buick with the 3800 engine that had dexcool in it. I had a water pump done. When done they filled with O'reilly yellow antifreeze universal that has turned a bit reddish as I guess the heater core retained some dexcool.
My questions
1) can I use ZEREX G-05 to top off
2) should I flush and use it
3) should I go back to dexcool
4) should I add O'reilly yellow antifreeze universal to top off
Re: Yellow plus red [Re: wsteveg] #4817890 07/19/18 08:07 AM
K
Kira Offline
K
What year Buick?
It matters because the manifold gaskets which dissolved in the presence of Dex-Cool (thank you GM for that thoughtful design work) were changed to new materials after a certain year.
I don't know how Dex + G-05 + O'Reilly yellow play together.
Re: Yellow plus red [Re: wsteveg] #4817906 07/19/18 08:18 AM
E
edwardh1 Offline
E
another thing the auto industry screwed up- something simple like antifreeze in the past now 8 varieties
These products are all new every year?? They are a revolution!!! Razor blades, mens shirts, TVs, wiper blades, gutter guards, hearing aids... according to the ads. But also all new last year
Re: Yellow plus red [Re: wsteveg] #4817907 07/19/18 08:18 AM
W
wsteveg Offline OP
W
It's a 2002 Regal.
Re: Yellow plus red [Re: wsteveg] #4817953 07/19/18 09:01 AM
J
JustN89 Offline
J
I would flush it and fill it with ZEREX G-05. That's what I have in my '05 Impala and it works well.
Re: Yellow plus red [Re: wsteveg] #4818136 07/19/18 01:18 PM
B
BJD78 Offline
B
Zerex and Prestone prefer to use the term "Global" to describe antifreeze while some brands like O" Reilly or Durex or Napa, pep boys etc calls it "universal" either way they are the same thing and work with all makes models.
Some folks calls it a kaiser blade and some folks calls it a "sling blade".
2010 Forester:122K
2009 Sonata :189K
OCI 5K using TSC conventional Travelers oil.
Re: Yellow plus red [Re: wsteveg] #4822778 07/25/18 11:57 AM
SirTanon Offline
I could be wrong, but I believe "O'reilly yellow" is basically just another spin on Dex-cool.
2013 Nissan Altima SV - 2.5 liter/CVT - 118,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 67,000mi
2010 Ford Fusion - 274,500mi
Re: Yellow plus red [Re: wsteveg] #4922607 11/12/18 10:04 PM
DONWATERS Offline
I would drain it, fill with water. Drive a few days, repeat. Once it looks clear go with cheap walmart universal green and water. I don't like the non green conventional coolants, when green is proven.
Re: Yellow plus red [Re: DONWATERS] #4949279 12/11/18 07:41 PM
N
nthach Offline
N
Walmart green is Dex-Cool, just dyed greenish yellow and no GM approval for warranty service.
The OP shouldn't have a problem with using "universal" antifreeze, as long as it has 2-EHA and sodium neodecoanate in it. NO G-05.
