Whirlpool wgd5560sq0 gas dryer
noticed the automatic dry setting wasn't working and dryer was running 2 hrs later. Clothes were cool and damp.
Unplugged dryer and tried timed mode and auto mode again.
After sitting for 30 mins the burner would work for about 5 mins on both modes.
I initially noticed this after using the High heat setting once, typically just use medium or low heat.
Cleaned the dryer vent, goodness.
Full old Bobby pins and junk.
Read on YouTube that the gas valve solenoid can get cooked and die.
I took them out and tested at room temp with multimeter ,1300 each . Good.
Then a comment on YouTube said to blast them with a hair dryer for a few mins and then check simulating their temp in a hot dryer enclosure.
Sure enough the smaller solenoid had no continuity when heated.
Set arriving today with free same day shipping from Amazon.
My guess is my lack of dryer vent maintenance killed the solenoid, so go clean yours if you haven't this year.
