Originally Posted by slacktide_bitog
Thank you for the cut and post
My choice for this application would be the M1-404A because the price is about the same but is good for 20k miles. This is one of those cars where I would only change the filter every other OCI because the filters are so expensive
The Fram Ultra is over $30, maybe you could get one of those and replace it every 5 years! Even from Rock Auto it's over $25
You can get a case of 12 Frams on eBay for $60, so it's $5 each, or there's this cheap
Super Auto filter for $55/case, with an option to submit a best offer to make the price even less. If they take $48 for the case, then that is a good deal since that would be $4/filter.
AAP and Autozone price the M1-404 like all other M1 spin-on cans, so they are included in the oil change deals for the same price. The best thing to do is get the M1 oil + M1 filter deal at AAP with the M1-404
There is a Purolator Boss available for this engine, but Purolator isn't known for their quality, and the boss has ADBV tearing problems. Otherwise, AAP has it for $16.99 regular price (half the price of the Fram Ultra), and with a promo code, you can get it for even less. It is frequently included in AAP's oil change deals, too.
RockAuto has the Fram Ultra for $22.79, which is less than $25, not over.
It's still a $18 filter at WalMart. The standard Mann filter (which is the OEM) is good for up to 30,000 km flexible service interval, if it was configured for it.
The Mobil 1 20,000 mile claim …. look at their warranty terms:
Champion Laboratories, Inc. provides this limited warranty to the original purchaser who use Mobil 1â„¢ Extended Performance oil filter products manufactured or sold by Champion Laboratories, Inc.,
which are warrantied to be free from defects in material and workmanship for the duration of the original equipment recommended change interval.
For part numbers without "A" suffix (e.g., M1-110) - Up to 1 year or 15,000 miles, whichever comes first, when combined with a fully synthetic motor oil designed for your intended oil change interval.
For part numbers with "A" suffix (e.g., M1-110A) - Up to 1 year or 20,000 miles, whichever comes first,
Mobil and Champ labs will argue since one didn't use the Mobil 1 Annual Protection oil (say, if you used Mobil 1 0w40 Euro car formula instead), in conjunction with the Mobil 1 A-filters, the 20,000 mile filter life is void, as it should be replaced in accordance to the original equipment change interval (10,000 miles).
You can get a 10-pk of Mann filters for $107.50, https://www.ecstuning.com/b-mann-parts/oil-filter-pack-of-10/06j115403c~man10/ which makes it $10.75 per filter, so it's really not that expensive, if you know where to shop.
https://www.shopdap.com/catalog/pro...udi-2-0-t-tsi-oil-filter/category/24631/ $9.59 per oil filter.
Good ole Rockauto has them for $9.78 a filter
