Originally Posted by zeng
Does HPR 5W40 (or any other Penrite xW40 that you know of ) carries a Moly/Boron/Titanium additives in its formulations ?
If yes, it may help in
this thread.
Originally Posted by Penrite
Zinc is part of an anti-wear Additive used to coat metal surfaces and be a sacrificial agent against wear. Penrite products containing FULL ZINC have between 1000 - 1600 PPM (Parts Per Million) of zinc. Penrite 10 Tenths Racing and Premium Full Synthetic Oils contain FULL ZINC+, which have optimised Zinc Levels plus Boron and an organomolybdenum complex (Racing 0 & 5 only), to lift the total level of the anti-wear package to over 1800+ ppm for the Premium FS range and 2200+ ppm for the Racing range.
Together with FULL ZINC and EXTRA TEN, this combination provides an EXTRA LAYER or DOUBLE LAYER of engine wear protection over normal engine oils at operating temperature. This ADDED LAYER of protection from FULL ZINC and EXTRA TEN improves wera protection and engine longevity.
Link = here
Looks like Penrite run with a Boron additive booster
only their 10/10th's range with MoDTC in 2 limited cases. One cannot say for sure, without a VOA as to the actual levels and specific mix's of these additives.
Penrite however, do-not use any Ti based antiwear additives. ONly Castrol and 1 or 2 others do (i believe there are some trade secret / patent pending
hocus-pocus going on in regards to it.
If you' looking for a high quality synthetic that has a good blend of both BN and MoDTC, you can't got past Shell Helix Ultra 5W40. It's a 'lite' 40wt that meets A3/B4, SN, BMW LL-01, Ferrari, Porsche A40...
Or for something chock full of BN, Helix Ultra ECT C2/C3 0W30 which has close to 500ppm Boron
It's a 'heavy' 30wt, meets SN, C2/C3, VW504/507. (Works awesome on old Saab turbo's
Regards
Jordan
