The googles didn't bring much up unfortunately except don't mess with aluminum heads.
I have an old Allis tractor I am currently doing a valve tappet adjustment on and wondered if it may be a good idea to check the head bolt (most are bolts, but 4 are studs) since I have the valve cover and sheetmetal off the tractor to actually get at the bolts/studs.
This is a 60's all cast iron gasser that has probably never been opened up. My hypothesis is that slightly loosened or fatigued head bolts and the possible warped head could result in a blown head gasket, but retightening almost 60 years into service could prolong its life indefinitely if they had loosened.
Is this sound thinking, or could the old style gaskets eventually go out even with perfect clamping force?
Thank you.
Thank you.
