B bfleeman Joined Sep 3, 2018 Messages 191 Location Columbus Nebraska Dec 9, 2018 #1 What oils meet this spec? I haven't really seen any bottles labeled with it. Does Amsoil meet this?
S slacktide_bitog Joined Mar 20, 2008 Messages 16,131 Location USA Dec 9, 2018 #3 It's probably just SN or at the most equivalent to dexos1. Any synthetic 5w30 will meet ie
L LEADED Joined Jul 13, 2011 Messages 175 Location MICHIGAN USA Dec 9, 2018 #4 Superseded by new FORD Spec WSS-M2C 945 B1
SubieRubyRoo Joined May 15, 2012 Messages 9,008 Location The land of USA-made Subies! Dec 9, 2018 #5 WSS 945 is a 5W20, its what is called for in the MZR2.5s and others. For some reason 945 does not include any 0W20s.
dave1251 Joined Jul 15, 2005 Messages 13,189 Location Maricopa Arizona Dec 9, 2018 #6 Originally Posted by slacktide_bitog It's probably just SN or at the most equivalent to dexos1. Any synthetic 5w30 will meet ie Any API SN 5W20 will meet it.
dave1251 Joined Jul 15, 2005 Messages 13,189 Location Maricopa Arizona Dec 9, 2018 #8 Originally Posted by zeng 953 is an SN 0W30. Good catch. Also I it is not a active spec.
S SureshR Joined Oct 12, 2018 Messages 296 Location Chennai TN India Dec 9, 2018 #9 These ford specs are typically ACEA A5/B5 with some additional ZDDP stuck in to meet a chain wear test, that'll push the petrol rating down to API SL. Any 5w30 A5/B5 should do the trick, else several do "meet or exceed" this ford spec.
