Gear lube 75W90 Synthetic GM# 88900401
by rcbob. 03/24/19 01:47 PM
Rislone Rebates
by Nickdfresh. 03/24/19 01:42 PM
IndyCar Classic at COTA
by bdcardinal. 03/24/19 12:29 PM
STP 500 at Martinsville
by bdcardinal. 03/24/19 12:27 PM
Source For Microfiber Towels
by Wrenchturner44. 03/24/19 12:26 PM
SUPREME C3-X SYNTHETIC 5W-30
by 21Rouge. 03/24/19 12:17 PM
Do you use your Pick Up like a truck or car?
by ZZman. 03/24/19 10:52 AM
My mom needs a new phone. Ideas?
by kpatter. 03/24/19 09:40 AM
2017 vw Jetta se vs 2017 Ford fusion se
by A1O. 03/24/19 09:39 AM
Fram Pro Synthetic #9688 **NEW** CUT OPEN
by 53' Stude. 03/24/19 08:26 AM
Wagner OEX vs Akebono ProACT
by Patrick0525. 03/24/19 08:12 AM
Plasti Diping my OEM rims question
by dblshock. 03/24/19 07:53 AM
"The new" Mobil 1 Racing Oil ?
by lawnguy. 03/24/19 06:32 AM
Arlen Ness passes
by 02SE. 03/24/19 03:15 AM
Plants - they learn and remember
by Shannow. 03/24/19 03:02 AM
Rotella Gas Truck
by jpstiles02. 03/24/19 02:53 AM
GSXRBullwinkie, Mark1970, FixItDad28, RandomJoe, Sciascia
67599 Registered Users
94 registered members (14Accent, A1O, Astro14, andyd, 97K15004WD, 8 invisible), 2,428 guests, and 52 spiders.
Topics286,339
Posts4,906,722
Members67,599
Most Online2,967
Mar 10th, 2019
Page 5 of 8 1 4 5 6 8
Re: Amsoil 0W-30, 14,198 MILES, 1993 Civic [Re: harry j] #4964692
12/29/18 09:00 PM
12/29/18 09:00 PM
Florida
Artem Offline
Artem  Offline
Florida
The original had 530k on it?!?! shocked2
2014 Mazda 3 Hatch 2.0L & 6spd - Idemitsu 0w20 Synthetic @ $0.75 a quart. (thanks Advance Auto Parts for the awesome deal)
Re: Amsoil 0W-30, 14,198 MILES, 1993 Civic [Re: harry j] #4965704
12/30/18 10:15 PM
12/30/18 10:15 PM
Wilmington, NC
harry j Offline OP
harry j  Offline OP
Wilmington, NC
My apologies Artem, the 530,200 mileage figure was really a note to myself for when I just changed the PCV valve.
The thing is that I used to change the air filter and the PCV valve at 12,000 miles. Since I've been on this web site,
I learned that changing the air filter too often is not the best choice. So, I haven't been changing the PCV valve as
often as in the past. This one went 30,000 miles. I will have to rework my PCV valve interval back to 12,000 miles.
Re: Amsoil 0W-30, 14,198 MILES, 1993 Civic [Re: harry j] #4971731
01/06/19 09:41 PM
01/06/19 09:41 PM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
Originally Posted by harry j
Ah yes Garak, this oil will never be approved for Dexos1, gen2 due to higher than specified Sulfated Ash level. Even if it did, the expense of certification is steep.
Formulators had to reduce SA when CJ-4 came out and somehow managed. wink Now, I'm not sure how steep dexos1 certification is, but it is perfectly acceptable to me for Amsoil to make that disclaimer that they cannot meet dexos1 due to SA.
Plain, simple Garak.
Re: Amsoil 0W-30, 14,198 MILES, 1993 Civic [Re: harry j] #4971853
01/06/19 11:28 PM
01/06/19 11:28 PM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
Amsoil SAY that the price of certification is steep...TomNJ says otherwise.
But certification would mean that they have to retest every time they changed base oil supplier...thy don't want to do that and have said as much.
Because sometimes the simple things in life...
...simply don't know any better
Re: Amsoil 0W-30, 14,198 MILES, 1993 Civic [Re: Shannow] #4975428
01/10/19 07:24 PM
01/10/19 07:24 PM
Garak Offline
Garak  Offline
In reference to another thread, in the Euro section, I believe, there was mention that the testing is costly for various specifications. Of course. However, if you're going to claim to meet and exceed specifications (without actually getting formal approval), shouldn't the actual testing be done? I have zero problem with an oil saying (and we even see it from the majors) that it would meet all of GF-5 except it has too much phosphorus and/or has too high HTHS and/or is the wrong grade. If that's the case, I'm fine if they ran the other tests.
Re: Amsoil 0W-30, 14,198 MILES, 1993 Civic [Re: harry j] #4975588
01/10/19 09:53 PM
01/10/19 09:53 PM
Wilmington, NC
harry j Offline OP
harry j  Offline OP
Wilmington, NC
I see your point Garak and I would like to see such tests done as well.
Re: Amsoil 0W-30, 14,198 MILES, 1993 Civic [Re: harry j] #4975595
01/10/19 09:56 PM
01/10/19 09:56 PM
Wilmington, NC
harry j Offline OP
harry j  Offline OP
Wilmington, NC
I've had this annoying, just audible bearing noise, especially at low idle. To keep a longish story short, it turned out to be
the A/C idler bearing.
Re: Amsoil 0W-30, 14,198 MILES, 1993 Civic [Re: harry j] #4976281
01/11/19 04:47 PM
01/11/19 04:47 PM
TX
s2krunner Offline
s2krunner  Offline
TX
thats super clean engine bay and exterior for that age. Cleaner than my 5k miles Camaro! Are you first owner?
2018 Chevy Camaro 6.2L V8
2017 Ford Explorer 3.5 V6
2011 Ford Ranger 4 banger
Re: Amsoil 0W-30, 14,198 MILES, 1993 Civic [Re: harry j] #4976527
01/11/19 09:38 PM
01/11/19 09:38 PM
Wilmington, NC
harry j Offline OP
harry j  Offline OP
Wilmington, NC
s2krunner, I purchased this Civic in 2000, it had 64,000 miles on it at that time.
Now heading to 532,000 miles, I couldn't be happier with not only the performance, but also the utility of it.
Re: Amsoil 0W-30, 14,198 MILES, 1993 Civic [Re: harry j] #4976531
01/11/19 09:42 PM
01/11/19 09:42 PM
Wilmington, NC
harry j Offline OP
harry j  Offline OP
Wilmington, NC
I didn't start using Amsoil 0W-30 until it had 118,000 miles on it. I didn't find out about BITOG until quite a bit later.
Re: Amsoil 0W-30, 14,198 MILES, 1993 Civic [Re: harry j] #4977915
01/13/19 12:46 PM
01/13/19 12:46 PM
Atlanta, GA
pezzy669 Online content
pezzy669  Online Content
Atlanta, GA
That is a boat load of miles - WOW. Automatic transmission to boot, how many transmissions have you had to replace as i know those Honda boxes can be weak.
My sister had a '93 EX Coupe she drove to ~280k miles then handed it down to my stepbrother, he had it just shy of 300k when he did an oil change the old filter gasket stayed in place and it puked all the oil out and engine seized up so they sent it to the junker. This was a Minnesota car its entire life and it did not have it easy, coming from a V6 Corsica my sister pushed that thing HARD. "Normal" acceleration for her would be revving it out to 5000-5500 RPM to get to speed, I'm sure it was the same for my stepbrother. To this day they both wonder how many miles it could have gone had he not mucked up that oil change.
2011 Mercedes-Benz E350 4Matic - 85k miles
Re: Amsoil 0W-30, 14,198 MILES, 1993 Civic [Re: harry j] #4978020
01/13/19 02:41 PM
01/13/19 02:41 PM
Wilmington, NC
harry j Offline OP
harry j  Offline OP
Wilmington, NC
pezzy669, the transmission is the original unrebuilt automatic transmission. the only things I have done to it
is change the fluid often (every 10,000 miles) and use Amsoil ATF. I also got rid of the factory joke of a magnetic drain plug
and had special hi temp neodyium magnets made for it. I smashen out the piece of junk factory magnet, drilled the plug out 1/2"
deep and JB welded the magnet in. The JB weld was overkill as the magnet is so strong, that it would have held itself in the
Factory plug.
Re: Amsoil 0W-30, 14,198 MILES, 1993 Civic [Re: harry j] #4978025
01/13/19 02:45 PM
01/13/19 02:45 PM
Wilmington, NC
harry j Offline OP
harry j  Offline OP
Wilmington, NC
I have been posting on BITOG since the Civic had 241,000 miles, but I started using the Amsoil ATF at around 120,000 miles. The current
mileage is 532,000.
Re: Amsoil 0W-30, 14,198 MILES, 1993 Civic [Re: harry j] #4978596
01/14/19 04:15 AM
01/14/19 04:15 AM
Wilmington, NC
harry j Offline OP
harry j  Offline OP
Wilmington, NC
What do you BITOGERS think about putting one of the extremely strong Neo magnets inside the oil filter?
Re: Amsoil 0W-30, 14,198 MILES, 1993 Civic [Re: harry j] #4978772
01/14/19 10:54 AM
01/14/19 10:54 AM
Lancaster County PA
diyjake Offline
diyjake  Offline
Lancaster County PA
Factory plug.
I would like to see a picture of this. Amsoil ATF is awesome stuff and my go to ATF fluid.
