Cut the cord, finally
by 14Accent. 05/21/19 10:29 PM
Av Gas 100LL in small engines and other things
by earthmover1980. 05/21/19 10:11 PM
Yamaha R1 on the Autobahn
by AZjeff. 05/21/19 09:11 PM
Sea Foam question
by vavavroom. 05/21/19 08:40 PM
Study on detergent additives and abrasiveness
by addyguy. 05/21/19 08:33 PM
ST9688 oil filter on motorcycle?
by AuthorEditor. 05/21/19 05:56 PM
Circle K frustrations
by Mark72. 05/21/19 05:44 PM
Milesyn SXR, 0w20, 5,100mi, 2018 Mazda3 2.5L
by RayCJ. 05/21/19 05:42 PM
What filter are the 2AZ-FE owners using?
by 53' Stude. 05/21/19 05:28 PM
NEW TOUGH GUARD 4386 CUT OPEN
by 53' Stude. 05/21/19 05:26 PM
300v 5w40 vs Redline racing 15w40
by junkyard_sal. 05/21/19 05:25 PM
Honda 1.5T Edge 0W40 8,800mi.
by dblshock. 05/21/19 05:17 PM
Cub Cadet LTX1050VT keeps shredding mower belts
by oilpsi2high. 05/21/19 04:27 PM
What’s the best price for a set
by ShutdownCorner. 05/21/19 04:01 PM
So who uses Exxon-Mobil EHC basestocks?
by csandste. 05/21/19 03:40 PM
Thoughts on this article?
by RyanY. 05/21/19 03:27 PM
BG products any good?
by Chris B.. 05/21/19 03:22 PM
Would you rather have three cars or two?
by brages. 05/21/19 02:01 PM
Car shows had a good run.....
by rekit. 05/21/19 01:45 PM
Fordpuppy, Geowebby, slugworks, tlogic, Danr42
68172 Registered Users
97 registered members (AC1DD, 14Accent, 01rangerxl, 2015_PSD, AdditiveOCD, 4WD, 12 invisible), 1,641 guests, and 21 spiders.
Topics289,214
Posts4,964,716
Members68,172
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
'17 Nissan Titan #4945731
12/07/18 09:35 AM
12/07/18 09:35 AM
Oxford, MS
BigMoneyGrip Offline OP
Oxford, MS
I just got a used Titan with 11K on it. Nissan recommends 0W20 SN spec and 5K change intervals. Is there any oil more suited to this engine since it's direct injected? I've read that these motors shear the oil more because of the gears and such, so I have no problem with a 5K change interval.
What oil would you recommend? And what oil filter? I've always trusted Purolator but can switch brands if needed. No towing, just normal driving.
Thanks,
Scott.
Re: '17 Nissan Titan [Re: BigMoneyGrip] #4945742
12/07/18 09:47 AM
12/07/18 09:47 AM
Tri State Conservative
Zee09 Offline
Zee09  Offline
Fram Ultra I believe XG7317- TG7317- OEM filter OK and inexpensive
0w20 if a warranty is a issue- 5w30- 0w30 if not
"If I walked on water, they'd say I couldn't swim."
Re: '17 Nissan Titan [Re: BigMoneyGrip] #4945744
12/07/18 09:47 AM
12/07/18 09:47 AM
PimTac Offline
PimTac  Offline
Nothing wrong with Nissans recommendations. Why the worry?
2017 Mazda CX5
Havoline Pro DS 0w20
Roki OEM filter.
Re: '17 Nissan Titan [Re: BigMoneyGrip] #4945756
12/07/18 10:03 AM
12/07/18 10:03 AM
So. Calif.
turnbowm Offline
turnbowm  Offline
So. Calif.
For a GDI engine, would recommend a synthetic Dexos1 Gen2 oil of recommended (Owner's Manual) viscosity and OEM oil filter.
2015 Kia Optima EX 2.4L GDI
2015 Chevy Volt
Re: '17 Nissan Titan [Re: BigMoneyGrip] #4945809
12/07/18 11:13 AM
12/07/18 11:13 AM
5600 feet elevation, Arizona
double vanos Offline
How do you like the Titan? Hear very little about them in the press.
Sabine Schmitz is the Queen of the 'Ring; Svetlana Kapanina is the Queen of the SKIES...
Re: '17 Nissan Titan [Re: BigMoneyGrip] #4945817
12/07/18 11:28 AM
12/07/18 11:28 AM
Missouri
Oily_Thing Offline
Oily_Thing  Offline
Missouri
In 2015, Nissan recommended 5w30 for this engine.
2013 Cadillac XTS4 3.6
2015 Dodge Durango Limited 3.6
2011 Kawasaki Vulcan Voyager 1700
Re: '17 Nissan Titan [Re: BigMoneyGrip] #4945820
12/07/18 11:35 AM
12/07/18 11:35 AM
Central MA
rsalan Offline
rsalan  Offline
Central MA
A D1G2 0W-20 synthetic on rebate with a Fram Ultra. Prob 5K OCIs since it's GDI.
'17 Mustang GT - PUP 5W20 / Puro BOSS
'16 X4 xDrive28i - BMW 0W20 / MANN
'14 Civic LX - PP 0W20 / FTG
'03 Matrix XR AWD - PP 5W30 / FU
'98 Sienna - PP 5W30 / FU
Re: '17 Nissan Titan [Re: BigMoneyGrip] #4945823
12/07/18 11:43 AM
12/07/18 11:43 AM
Maricopa Arizona
dave1251 Offline
dave1251  Offline
Maricopa Arizona
Follow Nissans recommendation and OCI. It is really this easy.
don't use.
Re: '17 Nissan Titan [Re: BigMoneyGrip] #4945825
12/07/18 11:48 AM
12/07/18 11:48 AM
1/2 hr N.E. of Detroit
Triple_Se7en Offline
No need for an Ultra for 5K OCIs. Use OEM Nissan filter and any 0W20 oil that meets Nissan's specs.
19 Hyundai SantaFe 2.4GDI Castrol Edge 5w30 / NAPA Mann-Hummel filter / 6oz Liqui-Moly Treatment
04 Colorado 3.5 Castrol Edge 0W40 Euro & K&N filter
03 Malibu 3.1 QS / Valv Syn 5w30 mix Fram EG filter
Re: '17 Nissan Titan [Re: dave1251] #4945827
12/07/18 11:49 AM
12/07/18 11:49 AM
South Wales, UK
Bailes1992 Offline
Bailes1992  Offline
South Wales, UK
What's the point in this forum then?
Shut it down folks, just follow the manual.
If the engine is hard on oil and out of warranty go to an*w30.
'17 Volvo V40 D3 Geartronic - Castrol Edge 5w30 LL
'19 Dacia Sandero 0.9T - Shell Helix Ultra 5w40
'96 LR Defender 300TDi - Morris Lubricants HD4 15w40
'12 BMW 320d Sport Auto - Fuchs GT1 5w40
Re: '17 Nissan Titan [Re: BigMoneyGrip] #4945849
12/07/18 12:10 PM
12/07/18 12:10 PM
South Carolina
ka9mnx Offline
ka9mnx  Offline
South Carolina
OEM filter. SN+ and/or d1g2 oil and grade/brand of your choosing. They are all good oils. Conventional oil at 5k OCI would be fine but you can use synthetic.I would lean towards 5w-30 A5 since it is not TGDI.
2005 Ranger 3.0 - M1 HM 5w-30/Motorcraft 85k+
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota 255k+
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar 175k+
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft 250k+
Re: '17 Nissan Titan [Re: BigMoneyGrip] #4945906
12/07/18 01:28 PM
12/07/18 01:28 PM
Ca.
UncleDave Online content
UncleDave  Online Content
Ca.
Id run Idemitsu Zepro advanced moly 0w20 if it were mine and change between 5 &7K
When it started to age Out of warranty and loosen up Id switch to a high PAO 30
Mine runs an xg7317.
UD
Uncle Dave
Cat 3126/2 MB3500/Titan/RX400H/17 Ridgeline
700HP V10/ 725HP BBC/ Raptor 700/ KFX450/ YZ250/Onan 8K/ Cat3011C
Re: '17 Nissan Titan [Re: Triple_Se7en] #4946146
12/07/18 07:22 PM
12/07/18 07:22 PM
Ca.
Ca.
filter and OCI doesnt have to be 1-1
Id still run one and do a topside change and just leave the filter in place for 3-4 OCI's. Way easier and quicker.
Uncle Dave
Re: '17 Nissan Titan [Re: Bailes1992] #4946221
12/07/18 09:05 PM
12/07/18 09:05 PM
Maricopa Arizona
dave1251 Offline
dave1251  Offline
Maricopa Arizona
And you are who?
don't use.
Re: '17 Nissan Titan [Re: BigMoneyGrip] #4946511
12/08/18 10:07 AM
12/08/18 10:07 AM
He is Bailes and you are Dave.
I am Joe and again reiterate the need to stick to 5K OCIs with this engine, should the OP desire to be the last owner of this vehicle..
Page 1 of 3 1 2 3
