No more Meijer batteries!!
by bullwinkle. 02/22/19 06:24 PM
Valvoline premium blue tsc
by Dudemanmaximus. 02/22/19 05:38 PM
Echo won’t run on high speed
by artbuc. 02/22/19 05:36 PM
Roadside Assistance memberships
by paulri. 02/22/19 05:35 PM
Remembering Steve Irwin
by 2015_PSD. 02/22/19 05:27 PM
Transmission Cooler
by rcbob. 02/22/19 04:59 PM
Amazon: PP Euro 5W-40 $38 for pack of 6 quarts
by 1JZ_E46. 02/22/19 04:56 PM
89 Wrangler oil recommendations
by Chris142. 02/22/19 04:55 PM
New batteries failing on the shelf
by Chris142. 02/22/19 04:53 PM
Schaeffer’s 5w30 LT1
by s2krunner. 02/22/19 04:48 PM
Lexus LS430 P0756
by Kibitoshin. 02/22/19 04:41 PM
PUP is now SN + ??? Formulation change??
by Lazydan. 02/22/19 04:17 PM
Got a new wireless printer/MFC
by y_p_w. 02/22/19 02:48 PM
NM
by y_p_w. 02/22/19 02:47 PM
Names of brand names quality non-pro multi-meter
by JLawrence08648. 02/22/19 02:16 PM
Lady Luck
by CourierDriver. 02/22/19 02:06 PM
Ford MPG
by Zee09. 02/22/19 02:03 PM
Canucks in need of licensed ATF+4
by StevieC. 02/22/19 12:42 PM
jcthorne, duckthis1, Roughneck777, KDW, avantika31
67313 Registered Users
117 registered members (10WSmuckers, 928, AandPDan, AdditiveOCD, 69Torino, 11 invisible), 1,772 guests, and 51 spiders.
Topics284,678
Posts4,874,943
Members67,313
Most Online2,548
Feb 16th, 2019
SCA's for perkins? #4945615
12/07/18 02:17 AM
12/07/18 02:17 AM
SF bay area, San leandro, Ca
Dualie Offline OP
Dualie  Offline OP
Cant get a strait answer on weather or not i need to add SCAs to standard low silicate coolant in my perkins 4 CYL that runs my Lincoln Electric Classic 300D. i have to put in a new radiator so might as well do a flush and fill. Anyone reccomend a ELC for this application? I does NOT have a recovery bottle so im tempted to keep the standard green for ease of refill down the road
Re: SCA's for perkins? [Re: Dualie] #4945689
12/07/18 07:19 AM
12/07/18 07:19 AM
Deplorable in apple valley, ca
Chris142 Online content
Chris142  Online Content
It won't hurt if you do and it does not require it.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: SCA's for perkins? [Re: Dualie] #4945707
12/07/18 07:54 AM
12/07/18 07:54 AM
NC
BigD1 Offline
BigD1  Offline
NC
Perkins says ELC with no SCA.
Perkins ELC: Contains no silicates, phosphates or borates, which are present in some other coolants and can cause corrosion
I looked at a MSDS, and it looks like it is run of the mill that contains 2eha.
https://www.perkins.com/en_GB/aftermarket/maintenance/consumables/coolant/coolant-protection.html
1992 Toyota Pickup--PYB 10W-30--Fram PH3614
Re: SCA's for perkins? [Re: Dualie] #4945876
12/07/18 11:38 AM
12/07/18 11:38 AM
Canyon County Idaho
CT8 Online content
CT8  Online Content
Canyon County Idaho
Peak final charge.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: SCA's for perkins? [Re: Dualie] #4946121
12/07/18 05:46 PM
12/07/18 05:46 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
John Deere CoolGuard II from the local dealer is just the ticket, its a diesel rated long life coolant suitable for almost anything including mixed metal and plastic.
I have been using it for the last 10 years (starting with CG I) in everything from diesels, all iron engines with copper cores, all aluminum engines with aluminum cores and plastic tanks, etc and never had any issues or corrosion.
Re: SCA's for perkins? [Re: Dualie] #4946170
12/07/18 06:49 PM
12/07/18 06:49 PM
Dualie Offline OP
Dualie  Offline OP
I have much stock on the Ford low silicate conventional antifreeze that works in most of all the older diesels, Just wondering if i needed to add SCA's to the system
Re: SCA's for perkins? [Re: Dualie] #4946487
12/08/18 08:50 AM
12/08/18 08:50 AM
Trav Offline
Trav  Offline
I would use it in that coolant just as insurance, it wont do any harm if its not needed.
Moderated by  ekpolk
