No more Meijer batteries!!
by bullwinkle. 02/22/19 06:24 PM
Valvoline premium blue tsc
by Dudemanmaximus. 02/22/19 05:38 PM
Echo won’t run on high speed
by artbuc. 02/22/19 05:36 PM
Roadside Assistance memberships
by paulri. 02/22/19 05:35 PM
Remembering Steve Irwin
by 2015_PSD. 02/22/19 05:27 PM
Transmission Cooler
by rcbob. 02/22/19 04:59 PM
Amazon: PP Euro 5W-40 $38 for pack of 6 quarts
by 1JZ_E46. 02/22/19 04:56 PM
89 Wrangler oil recommendations
by Chris142. 02/22/19 04:55 PM
New batteries failing on the shelf
by Chris142. 02/22/19 04:53 PM
Schaeffer’s 5w30 LT1
by s2krunner. 02/22/19 04:48 PM
Lexus LS430 P0756
by Kibitoshin. 02/22/19 04:41 PM
PUP is now SN + ??? Formulation change??
by Lazydan. 02/22/19 04:17 PM
Got a new wireless printer/MFC
by y_p_w. 02/22/19 02:48 PM
NM
by y_p_w. 02/22/19 02:47 PM
Names of brand names quality non-pro multi-meter
by JLawrence08648. 02/22/19 02:16 PM
Lady Luck
by CourierDriver. 02/22/19 02:06 PM
Ford MPG
by Zee09. 02/22/19 02:03 PM
Canucks in need of licensed ATF+4
by StevieC. 02/22/19 12:42 PM
jcthorne, duckthis1, Roughneck777, KDW, avantika31
67313 Registered Users
110 registered members (10WSmuckers, AandPDan, AdditiveOCD, 69Torino, 2004tdigls, 7 invisible), 1,836 guests, and 50 spiders.
Topics284,677
Posts4,874,933
Members67,313
Most Online2,548
Feb 16th, 2019
Page 1 of 3 1 2 3
What would you do differently in maintaining your car? #4945530
12/06/18 10:24 PM
12/06/18 10:24 PM
New Mexico, USA
jimbrewer Offline OP
New Mexico, USA
Most of us have developed a little regimen for maintaining our cars.
What would you do differently if starting over?
For me, when I found out how much it costs to replace a water pump in an F-150, I wouldn’t have waited 5 years (as per manual) to make the first coolant change.
Otherwise, through the school of hard knocks I’ve gotten better about keeping a car up besides incessantly changing the oil.
What about you guys?
Re: What would you do differently in maintaining your car? [Re: jimbrewer] #4945533
12/06/18 10:30 PM
12/06/18 10:30 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Quote
I learned this lesson from my uncle when he had to replace the heater core in his F150.
Learning from him, I now do regular coolant changes
Re: What would you do differently in maintaining your car? [Re: jimbrewer] #4945536
12/06/18 10:34 PM
12/06/18 10:34 PM
Virginia
bbhero Offline
bbhero  Offline
Virginia
Really good point Linctex.
I am glad I figured that out has well... Has saved me in the long run now.
Nissan Altima 3.5 Coupe
Mobil Super 5w30 Wix 57356
"Treat your family like your friends and treat your friends like your family."
Re: What would you do differently in maintaining your car? [Re: jimbrewer] #4945537
12/06/18 10:34 PM
12/06/18 10:34 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
I'd have gotten off my lazy [censored] and changed the coolant and transmission fluid in the Sonata. No issues, but I should have done it earlier. Oh well.
This summer I put a new power steering pump on my Jeep, was over $350 just for the pump. Also replaced the return hose. The high pressure hose looked good (original) and I decided against replacing it. Then the other weekend I drove it out of town and it sprung a leak, sprayed fluid on the exhaust and had a plume of smoke coming out of the hood. I'm an idiot sometimes duh
2015 Hyundai Sonata 2.4L 91k Motorcraft Synthetic Blend 5w30 & OEM
2000 Toyota Camry 2.2L 232k Valvoline 5w30 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: What would you do differently in maintaining your car? [Re: jimbrewer] #4945544
12/06/18 10:48 PM
12/06/18 10:48 PM
Venezuela, South America
Emanuel Offline
Emanuel  Offline
We had a 297k miles Corolla, we never changed the manual transmission fluid, and maybe if we did we would have prevented it´s failure, at 210k miles it used to pop out of 4th gear.
We never adjusted valve clearances, and I´m pretty sure that was the reason why a exhaust valve of the #1 cylinder burned at 250k miles.
The coolant thermostat that came from the factory lasted 11-13 years, we installed a cheap aftermarket one that lasted only 1 year and our mechanic decided to remove it completely, it only reached operating temperature on the noon while driving in heavy traffic. Of course the coldest temp that the car saw was 70° F but even in hot climates an thermostat is very important.
Using water as coolant, the car never overheated using water and no thermostat but it would have been better to use Toyota Coolant and also a OEM Thermostat.
Never buying cheap radiator caps, the car needed a head resurface and a head gasket two times because of this, but on the good side it was cool to see and touch the cylinders at 289k miles, they didn´t had any signs of wear, neither a ridge.
Doing power steering fluid flushes and filling it with new fluid, to see if it would have helped it to last a longer time (it was leaking since 200k miles).
Change the PCV, try to use thinner oils (the thinnest that we used was 15w40) to see if oil consumption slowed down.
We also used to change oil every 3k miles, because living in Venezuela we were never sure of the quality of the engine oil, but the next time I own a car I will try do 5 to 7k mile OCI, 3k miles OCI are a waste of oil and a considerable damage to the environment
Re: What would you do differently in maintaining your car? [Re: jimbrewer] #4945568
12/06/18 11:29 PM
12/06/18 11:29 PM
[email protected] CZ firearm factory
Marco620 Offline
Marco620  Offline
I have done an awesome job all around. I change cvt fluid q 20-30k but I would have started using Castrol Transmax/Redline CVT fluid sooner. I would have started my Redline 0w20 & Archoil regimen MUCH sooner although I used Lubegard Biotech early on with Magnatec and then PUP so its not a total loss. Using non ethanol for almost entire time with PEA so no issues there. Cant complain much. The success or failure of a vehicle is threefold. The idiot who owns the car,services the car, and assembles the car. Hope all three never meet,but if you can be the first two and at the very least follow the monitors or book then if it fails you know for sure it was beyond your control. I dont think even the way I spend on a car that I could get a Yugo GVX to 200,000 miles using the same measures I did with my Civic "tsu chen".
15' Civic 1.8 i-vtec 213,000 mi 0w20 Redline/Redline CVT/Archoil9100/TEIN/Eibach/Tanabe Sustec/Borla Exhaust/87 E0 fuel/Yokohama
Son of a Navy Corpsman. Support vets!
Re: What would you do differently in maintaining your car? [Re: jimbrewer] #4945591
12/07/18 12:55 AM
12/07/18 12:55 AM
CA
The Critic Online crying
The Critic  Online Crying
CA
Currently I change the oil every 5K, replace all fluids (except coolant) every 30K and plugs at the OE Interval. Any oil leaks or seeps are immediately dealt with. Any normal-wear issue is addressed.
But on my next car...
Once out of warranty, I would base my maintenance schedule on the vehicle's current resale value. With labor rates being over $150/hr in my area (and many others), it is simply not economically feasible to "maintain" a high mileage vehicle, especially economy ones.
When in-warranty, I would of course follow the OEM maintenance schedule. Once out of warranty, I would only keep the car in good condition for as long as the vehicle has a reasonable resale value. For instance, it does not make sense to spend thousands to repair normal-wear items (struts, oil leaks, engine mounts, spark plugs, etc) unless they are safety-related if your 120K mile-old car is only worth $5K. I think vehicles have always had a designed service life, but nowadays, it is more evident than ever. I would also plan on sell/trading by 150K.
2011 Toyota Prius - 184k - M1 EP 0W-20
2007 Honda Accord 2.4 - 134K - Mobil 1 EP HM 5W-30
Re: What would you do differently in maintaining your car? [Re: jimbrewer] #4945634
12/07/18 04:48 AM
12/07/18 04:48 AM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
Although it hasn’t bit me yet, those stupid weepy crimped hoses for the transmission cooler lines should probably be attended to. Also, although I’ve never had a fuel pump failure in the 150,000 miles I used to use as the mileage to replace the vehicle, might as well stay on top of the fuel filter changes to lessen the stress on the pump.
If you want the job done right......do it yourself.
Re: What would you do differently in maintaining your car? [Re: jimbrewer] #4945637
12/07/18 04:58 AM
12/07/18 04:58 AM
Snagglefoot Offline
Snagglefoot  Offline
Given the issues with some cars and trucks’ OHC timing chains I’m not sure if I would push OCI’s on them. The prize is not worth the consequences if a chain wears prematurely. One other thing. Many place the front diff, rear dif and transfer case on the same maintenance schedule. I would step it up on the transfer case and change it twice as much, especially if you use four wheel drive a lot or have AWD. Thanks to the OP for suggesting the topic.
Re: What would you do differently in maintaining your car? [Re: The Critic] #4945641
12/07/18 05:12 AM
12/07/18 05:12 AM
Chicagoland
Skippy722 Online content
Skippy722  Online Content
Chicagoland
Pretty much this. My Caliber is at 94k, and I honestly could not care less that the sway bar bushings are rattling around. I’m the only person who drives it, and it only gets driven at most 100 miles a week. But I keep an eye on everything else, the rest of it’s all still nice and tight. There’s cardboard between the radiator and condenser because it’s been cold and I can’t be bothered to actually replace the thermostats in the cold... I’ll get around to it eventually.
As for the family car, I keep up with that. If something needs addressed, I’m addressing it and addressing it properly, unlike the Caliber. It’s also my “I feel like going for a drive” car, because it makes me feel “classy AF!”
2016 Chrysler 300S v6
2012 Dodge Caliber SXT
Re: What would you do differently in maintaining your car? [Re: Linctex] #4945650
12/07/18 05:47 AM
12/07/18 05:47 AM
Central NY
rsylvstr Offline
rsylvstr  Offline
Central NY
Agreed. My local mechanic said the other day “nah. You don’t need a flush. It looks good.”
2013 52k
Same with brakes. So sometimes PepBoys or dealer are the way to go for me.
2013 F150 SCrew Lariat 4X4 5.0 3.55
2012 Altima SL that still vibrates.
2018 Polaris Sportsman 850 SP. Polaris fluids and filter.
Re: What would you do differently in maintaining your car? [Re: jimbrewer] #4945662
12/07/18 06:11 AM
12/07/18 06:11 AM
south dakota
joekingcorvette Offline
south dakota
I noticed a lot of comments on anti freeze. I like to make sure it has a good new looking color all the time. I try to change it at least every three years if not sooner. I the Honda I change the AT fluid every 15,000 miles. It's a three quart drain and fill. I am going to start running my oil and filters longer since I am old school and tend to change before needed. I have had very good luck with my all my vehicles and previous cars and trucks. Sometimes I think I end up saving them for somebody else since I usually trade before anything hits 100,000 but I might try to keep them longer to keep from losing money every time I upgrade.
2005 Chevrolet Corvette
2014 Ford F-150 4x4 supercrew
2014 Jeep Grand Cherokee Limited (wifes)
2012 Honda Civic 4 door (my daily driver)
2007 Lund Tyee Grand Sport Mercury 115HP 9.8HP
Re: What would you do differently in maintaining your car? [Re: jimbrewer] #4945664
12/07/18 06:15 AM
12/07/18 06:15 AM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
Ahhh....an "if you could turn back the hands of time" question.
I'd never have been numb to the 4 seasons.
In other words, I'd have adhered to a maintenance schedule which kept me task free during Winter months.
Doo-doo head dumbski sometimes me.
Re: What would you do differently in maintaining your car? [Re: Kira] #4945665
12/07/18 06:17 AM
12/07/18 06:17 AM
Oshawa, Ontario Canada
JC1 Offline
JC1  Offline
I agreed Kira, plan that maintenance around the spring to fall months. This year I'll actually be changing oil in January but doing drain and fills with the fumoto and leaving the filters alone (FU).
I do regular fluid changes every few years. Considering a lot of people never even change brake fluid for the life of their cars or neglect spark plugs until the engine runs like crap, I think most of us here do a good job of keeping out maintenance practices better than most.
2015 Grand Caravan SXT Plus 5w-20 Valvoline SynPower/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: What would you do differently in maintaining your car? [Re: jimbrewer] #4945680
12/07/18 06:50 AM
12/07/18 06:50 AM
NY
demarpaint Offline
demarpaint  Offline
NY
I'd stick to what I've been doing, it seems to be working.
God Bless Our Troops
Page 1 of 3 1 2 3
Moderated by  ekpolk
