ATF+4 go with Mopar, Castrol, or other?
USA
Hi all. I picked up an '05 Dodge Neon a few months back, and it's looking like I should be changing the ATF fluid especially with a cold Colorado Winter ahead. I've never owned an automatic transmission in a vehicle so I need help. I'm not too familiar with the ATF+4 Spec fluid. My question is this, Do I go with OEM Mopar fluid from the local Dodge Dealership, or do I go pick up an ATF+4 compatible fluid from Castrol or Mobil 1? All help is much appreciated. Give me the good vs bad on OEM vs other.
If it was my vehicle I would pick any ATF+4... basically a fluid that's marketed primarily as an ATF+4 vs a universal fluid that is "compatible with ATF+4 applications" it doesn't really matter what brand you get... O'Reilly, Valvoline, whatever ATF+4 you can get the cheapest.
The best ATF to use where ATF+4 is called for is Redline C+ even though it is not licensed and doesn't appear on the approved list from CQA. Chrysler's ATF+4 licensing program is very strict and borderline childish, requiring only a specific group III base oil and a specific Lubrizol add pack, very heavy micromanagement.
Redline C+ uses the same add pack as licensed ATF+4 but with a group V ester base stock, which is why Chrysler won't license it.
If you're still under warranty, use the cheapest licensed ATF+4 on sale from the list someone linked above.
And since your Neon's transmission doesn't have a drain plug, you will want an aftermarket pan that has one, which will make future ATF changes much easier
I run Schaeffers Dexron VI/Mercon LV in my 98 neon. Shifts are smooth and lockup is perfect. Its not licensed by chrysler but on their data sheet it does show suitable use for ATF+4. Im sure any ATF+4 will eork just fine for you though.
I used Super Tech ATF+4 on the Jeep's last Transmission fluid exchange. Like was stated before, ATF+4 is a licensed product, so use whatever licensed ATF+4 that is listed.
I use Castrol ATF+4. AAP often runs it for good prices on sale making the choice very easy. In order for it to be labeled as AFT+4 and licensed as such, it is GTG in any Chrysler product calling for it.
anything that is genuine atf+4 is fine.. even supertech or amalie etc.
on that car I'd go hit up walmart for some supertech brand because its cost effective..
(vs going redline etc)
I have used various brands of transmission fluid for Mercon V. Castrol, Valvoline, Motorcraft, and Supertech. My vehicle was fine with all of them. I doubt you will detect any differences with AFT+4 with whichever brand you choose.
How much is that basestock group V? If it's like Redline Motor oil its 10% or less.
ATF+4 if it's licensed there are something like 2 group III basestocks and one additive package a blender can use so their all the same.
I don't know, but the properties seem much better than the licensed group III ATF+4
Not really the viscosity, viscosity index, and Brookfield viscosity are nearly the same. The one thing I can't compare is flash point because Redline does not list it. From what I see is the C+ has about 1% ester.
Redline C+ has a Brookfield of 3800 cP
Castrol ATF+4 Brookfield is 8380 cP (Here is a PDS I found), other licensed ATF+4 shopuld be around the same
I was able to find the C+ flash point in their MSDS, 148C/298F, kind of low and disappointing. Licensed ATF+4 flash point is higher by 50C/90F (per the Castrol PDS)
I hope P66 didn't cheapen it
Originally Posted by Skippy722
Never had a problem with Supertech ATF+4 in my Mopars.
You should not. It is the same as all other ATF+4.
