Originally Posted by OVERKILL
Originally Posted by edhackett
You won't see anything happen under those conditions. The problem with the chlorinated additives is when they enter the combustion chamber. The chlorine is released when the additive burns and combines with H to form HCl, which is a corrosive gas. HCL dissolves in water forming hydrochloric acid.
Ed
Could one not add heat to the proposed test to try and create that effect?
No, you would need to reproduce the heat, pressure, and chemical soup found inside the combustion chamber.
Ed
Ed
Ed
