Mobil 1 Syn Gear Lube LS 75W-140 is recommended for use in modern high performance vehicles like sport utility vehicles, vans and light duty trucks requiring API GL-5 performance that require excellent durability
Mobil 1 Syn Gear Lube LS 75W-140 is intended for initial fill, topping-off or refilling differentials, final drives, transfer cases and other gear applications where lubricants meeting API Service GL-5 and multi-purpose or mild EP gear lubricants are recommended
Mobil 1 Syn Gear Lube LS 75W-140 can also be used in rear axles where API Service GL-4 lubricant is recommended
Not recommended for automatic, manual or semiautomatic transmissions for which engine oil or automatic transmission fluids are recommended
Recommended for many limited slip applications. For certain high level LS applications, additional limited slip additive may be required if axle chatter is observed.
Mopar LSD additive Part# MS-10111 if needed.
