Need surge protector for oversize adapters
California
I am looking for a surge protector/power strip with individual switches for my computer and peripherals. The problem with all the power strips I find is that the outlets are too close to each other and I can use only every other outlet because the power supplies are too big. I only see one kind of powerstrip for large power supplies. It is semi-circular, which is fine but it does not have individual switches. Any suggestions?
I just hook lots of cheap ones together, after one "GOOD one" to feed them..
It isn't neat... but it works.
Would short extension cords help with your brick type power adapters?
[Linked Image]
https://www.amazon.com/6-Inch-Power...r=8-4&keywords=extension+cord+6+inch
Originally Posted by Donald
Some power strips are built to accommodate a row of power cubes.
I can't find any with individual switches.
Originally Posted by 4WD
A power tower has a switch at each level
That will work! I saw similar towers but none had switches. I'll buy two of those. Thanks for the suggestion.
I do like that power tower idea, too. The little short extension cords are very clever, too, but I imagine they'd be better off used in moderation, with respect to cable salad, as you indicated.
