Carbon - Soot
by WyrTwister. 05/22/19 08:07 AM
Radiator Half Full
by Mark72. 05/22/19 07:04 AM
Another RA discount code#
by Char Baby. 05/22/19 06:44 AM
Water leak from passenger door?
by HoosierJeeper. 05/22/19 06:40 AM
Motul 300v 5w40 vs Redline 40WT racing in BMW racecar
by junkyard_sal. 05/22/19 06:23 AM
Someone smoked in my company truck
by Cujet. 05/22/19 06:19 AM
Cross Country Oil Choice ?
by ChrisD46. 05/22/19 03:06 AM
Calling all gen2 3.5 Ecoboost owners
by double vanos. 05/21/19 11:51 PM
15 Chevy malibu
by earlyre. 05/21/19 11:16 PM
Align 3 blade deck
by rekit. 05/21/19 10:51 PM
Cut the cord, finally
by 14Accent. 05/21/19 10:29 PM
Av Gas 100LL in small engines and other things
by earthmover1980. 05/21/19 10:11 PM
Yamaha R1 on the Autobahn
by AZjeff. 05/21/19 09:11 PM
Sea Foam question
by vavavroom. 05/21/19 08:40 PM
Study on detergent additives and abrasiveness
by addyguy. 05/21/19 08:33 PM
ST9688 oil filter on motorcycle?
by AuthorEditor. 05/21/19 05:56 PM
52Voodoo, HondaHrX, DirkDiggler87, Fordpuppy, Geowebby
68175 Registered Users
98 registered members (2004tdigls, andrewp1998, AurionX2, BeerCan, 1978elcamino, 7 invisible), 1,638 guests, and 31 spiders.
Topics289,227
Posts4,964,944
Members68,175
Most Online2,967
Mar 10th, 2019
2015 Skyactiv OCV Failed Again #4939535
11/30/18 09:59 AM
11/30/18 09:59 AM
NJ
buster Offline OP
buster  Offline OP
NJ
After having the OCV replaced about 2 months ago, I noticed yesterday that it is leaking again. I was told they either didn't install it right or there is a crankcase vacuum issue. Taking it to the dealer December 12th. I'm curious what they find. I'm taking it to a different dealer this time. Car is still under warranty (55k miles).
Re: 2015 Skyactiv OCV Failed Again [Re: buster] #4939553
11/30/18 10:24 AM
11/30/18 10:24 AM
PV Az @ 5000'
AZjeff Offline
AZjeff  Offline
PV Az @ 5000'
Had to look that up. >Here's how it works< if curious. Can you tell if it's not working?
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP
18 Nissan Titan 5.6 DI, QSUD
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: 2015 Skyactiv OCV Failed Again [Re: buster] #4939558
11/30/18 10:31 AM
11/30/18 10:31 AM
NJ
buster Offline OP
buster  Offline OP
NJ
I'm going to see if the PCV is pulling a vacuum later today by pulling the oil cap when the car is running and putting my hand over the filler. Thanks for sharing that AZjeff. smile
Re: 2015 Skyactiv OCV Failed Again [Re: buster] #4939576
11/30/18 10:47 AM
11/30/18 10:47 AM
San Antonio, TX
E150GT Online content
E150GT  Online Content
San Antonio, TX
Does your engine have a lot of blowby? If I remove the oil cap while the engine is running it sounds like a worn out diesel and sprays oil droplets all over.
1984 Mercedes-Benz 300SD - 100k
1995 F150 XL 4.9 reg cab 5MT - 251k 5w30
2016 Mazda6 Touring 6MT - 57k 10w30
2006 Buick Lucerne CXL 3.8 31k 5w30
Re: 2015 Skyactiv OCV Failed Again [Re: buster] #4939599
11/30/18 11:14 AM
11/30/18 11:14 AM
NJ
buster Offline OP
buster  Offline OP
NJ
Not that I'm aware of. Oil stays on full mark through the entire interval and fairly golden color. There was one time (last winter) due to extremely short trips to work (less than 7 miles in severe cold) where the oil level went over the top fill mark, but that was from fuel dilution. I have no explanation for this other than either the OCV is faulty, installed wrong or there is a crankcase vacuum issue.
The dealer that did the previous job botched the valve cover gasket and had to redo it. Hopefully this dealer does a much better job. The manager working with me is aware of the previous situation. I just have to hope I get a tech that isn't a dope.
Re: 2015 Skyactiv OCV Failed Again [Re: buster] #4939602
11/30/18 11:17 AM
11/30/18 11:17 AM
The land of USA-made Subies!
SubieRubyRoo Offline
E150GT, nearly any inline 4 will do the same as you describe... there is not a lot of crankcase volume, and with the pistons pumping up and down there is a lot of air movement that will blow some oil back up through the drain holes into the head and create the issue you describe.
Re: 2015 Skyactiv OCV Failed Again [Re: SubieRubyRoo] #4939618
11/30/18 11:35 AM
11/30/18 11:35 AM
NJ
buster Offline OP
buster  Offline OP
NJ
True, but the OCV are not supposed to leak regardless.
Re: 2015 Skyactiv OCV Failed Again [Re: buster] #4939675
11/30/18 12:40 PM
11/30/18 12:40 PM
PimTac Offline
PimTac  Offline
I wonder if the replacement was faulty?
2017 Mazda CX5
Havoline Pro DS 0w20
Roki OEM filter.
Re: 2015 Skyactiv OCV Failed Again [Re: buster] #4939696
11/30/18 01:02 PM
11/30/18 01:02 PM
NJ
buster Offline OP
buster  Offline OP
NJ
Possible. I'm just really irritated because they rushed the job last time and didn't properly seal the valve cover gasket. I had to take the car back 2x for them to fix it right. It was a rush job. They worked on the recall and the OCV at the same time and rushed it through. I've heard not so good things about this dealer too. So now I'm going to the better one and the manager knows the entire situation so they better get it right this time.
Re: 2015 Skyactiv OCV Failed Again [Re: buster] #4939701
11/30/18 01:12 PM
11/30/18 01:12 PM
CA
The Critic Offline
The Critic  Offline
CA
Technically, the seal failed - not the OCV itself.
I have one of these seals on my shelf and it appears to be a "press fit" type seal. If I recall correctly, this is a plastic cover, and plastic covers are usually not good candidates for press-fit type seals to be replaced. Nissan VQ35 valve covers with non-replaceable spark plug tube seals come to mind.
So, perhaps the cover itself is slightly deformed in that area and this is why it is not sealing?
2011 Toyota Prius 1.8L - 190K - Idemitsu ZEPRO Adv. Moly 0W-20
2007 Honda Accord 2.4 - 137K - Mobil 1 EP HM 5W-30
Re: 2015 Skyactiv OCV Failed Again [Re: buster] #4939723
11/30/18 01:40 PM
11/30/18 01:40 PM
NJ
buster Offline OP
buster  Offline OP
NJ
Hmmmm that's a very good point Critic. What are the chances the dealer tech will even think of that? LOL
Maybe I will bring this up to the them when I drop it off.
Re: 2015 Skyactiv OCV Failed Again [Re: buster] #4939798
11/30/18 02:52 PM
11/30/18 02:52 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
While all The fancy tech stuff is groovy, the more plumbing there is the easier it is to clog up the pipes.
2015 F150 2.7
2018 F350 6.2
Re: 2015 Skyactiv OCV Failed Again [Re: CT8] #4939888
11/30/18 04:58 PM
11/30/18 04:58 PM
PimTac Offline
PimTac  Offline
Maybe but the old cars were constantly being worked on as well.
2017 Mazda CX5
Roki OEM filter.
Re: 2015 Skyactiv OCV Failed Again [Re: buster] #5003263
02/06/19 05:04 PM
02/06/19 05:04 PM
NJ
buster Offline OP
buster  Offline OP
NJ
Dealership is replacing VC/Seal/OCV and it will be covered under warranty. I went to the dealer this morning to drop the car off. Service writer wrote up the problem wrong, so he re-wrote it. Service manager had one of their senior techs come out and I explained the problem. They called me back about an hour later and said it will be covered. I'm pretty happy they are going to cover it. Hopefully they do the job right this time. Parts have to be ordered but they gave me a 2019 CX3 loaner, which is not bad I have to say.
Re: 2015 Skyactiv OCV Failed Again [Re: buster] #5003327
02/06/19 06:22 PM
02/06/19 06:22 PM
ON, Canada
yugrus Offline
yugrus  Offline
ON, Canada
Hope the picture shows properly. Here's how mine looks like.
This time it's gotta be a charm for you!
'14 Chevrolet Tahoe
'15 Mazda CX-5
