Who makes NAPA windshield wiper blades?
by paulri - 11/20/19 11:07 AM
Leaking orange can
by Chris142 - 11/20/19 11:03 AM
Mobil 1 @ Costco $23.69/6 pack + tax
by deoxy4 - 11/20/19 10:12 AM
Interesting eBay experience
by dlundblad - 11/20/19 08:30 AM
Tires with traction
by Sierra048 - 11/20/19 08:20 AM
Engine RPM’s while passing
by Snagglefoot - 11/20/19 08:13 AM
Black Friday Sales
by Sierra048 - 11/20/19 08:12 AM
Need a dashcam hardwire kit
by cwilliamsws6 - 11/20/19 08:04 AM
Have you seen this YouTube testing?
by T-Stick - 11/20/19 07:46 AM
Messages on Android phone
by Donald - 11/20/19 06:17 AM
Cooper vs Continental SUV tires?
by Russ300 - 11/20/19 05:59 AM
Total energy vs Total ineo first
by Goran - 11/20/19 02:22 AM
Fram Ultra - Hot Tub Filter
by SavagePatch - 11/19/19 10:08 PM
Possible bad coil on Husky 150bt
by i6pwr - 11/19/19 09:52 PM
JD LVU800097
by Jason_Michaels - 11/19/19 09:09 PM
Chiappa M1-9
by GumbyJarvis - 11/19/19 09:05 PM
Power steering fluid change out; frequency.
by GeorgeMP - 11/19/19 08:59 PM
baileyclarke, Jbloggs, Pdlodge, Cubez007, dshadow
69921 Registered Users
97 registered members (1WildPig, 28oz, 01rangerxl, 1978elcamino, 94astro, 8 invisible), 2,142 guests, and 18 spiders.
Topics297,669
Posts5,120,317
Members69,921
Most Online3,589
Nov 2nd, 2019
Page 1 of 4 1 2 3 4
Marvel mystery oil vs Rislone engine treatment opinions #4937073 11/27/18 07:16 PM
T
Toh1 Offline OP
T
I have search every forum to find which is better for cleaning up engine sludge? I think Rislone has 20wt oil viscosity and contain additive like calcium magnesium and zinc and 11%tmp ester and marvel mystery oil is 5wt do not know ingredients. Which is better ?
Re: Marvel mystery oil vs Rislone engine treatment opinions [Re: Toh1] #4937119 11/27/18 08:00 PM
A
AVB Offline
A
I believe rislone is the better cleaner due to the ester content.
Re: Marvel mystery oil vs Rislone engine treatment opinions [Re: Toh1] #4937122 11/27/18 08:03 PM
Marco620 Offline
Does it have to be only one or the other? Are these two options at Walmart? My guess is Rislone but have you tried a better oil/filter combo instead first?
15' Civic 1.8 i-vtec 288,000 mi Mobil 0w30 & LG Biotech, BP CVT Fluid,Redline Si-1
Doberman Whisperer!
Honda,Doberman,CZ's & SONY Aficionado
Re: Marvel mystery oil vs Rislone engine treatment opinions [Re: Marco620] #4937136 11/27/18 08:12 PM
T
Toh1 Offline OP
T
I am asking if Rislone engine treatment or marvel mystery oil which is good. Both are available in Walmart and major Auto stores. I have tried pennnzoil platinum 0w20 and Mobil 1 0w20 high mileage wix or Mobil 1 oil filter for more than 2 years or 20k miles but my engine is making engine tick when accerating hard around 3 k rmps . I suspect I have piston rings sticking or engine lifters so I think so used mmo or Rislone engine treatment which will help clean engine and hopefully it will help my engine?
Re: Marvel mystery oil vs Rislone engine treatment opinions [Re: Toh1] #4937154 11/27/18 08:26 PM
Dinoburner Offline
Both have been around forever. Rislone seems quicker and will loosen sticky noisy lifters where MMO is better at loosening stuck rings if its poured into cylinders and let set. It`s also a good top oil. I use top oil in aircooled engines which reduces the metalic effect in drain oil
77 Chev stepside 454 Casteroil syn
95 GMC 4wd mobil syn
2016 Equinox LTZ V6 dealer
Kubota L5030 T6
Re: Marvel mystery oil vs Rislone engine treatment opinions [Re: Toh1] #4937165 11/27/18 08:38 PM
B
BMWR1150GS Offline
B
Rislone fan here. I have had several engines with noisy lifters and coked rings. I have used Rislone engine treatment in both cases and had good results with one treatment. Especially dirty engines will require more than one treatment.
Also, have a look at the MSDS sheet for MMO. Not much exciting going on there.
I used to wear a suit and tie, now I wear bibb overalls.
Re: Marvel mystery oil vs Rislone engine treatment opinions [Re: BMWR1150GS] #4937265 11/27/18 10:28 PM
L
Linctex Offline
L
The MSDS tells you nothing.
The recipe is in the archives here.... it has phosphorus based anti-wear (AW) compounds in it.
Re: Marvel mystery oil vs Rislone engine treatment opinions [Re: Toh1] #4937281 11/27/18 10:54 PM
O
Onetor Offline
O
Out of curiosity I went to Walmart.com and found Synthetic Rislone. It has Tungsten, Moly, and Esters. It's on rollback for $11.04 with a five dollar rebate. Not bad. I have no experience with this. First time I've seen this ester version. I doubt u need it with a quality synthetic oil, but every application is different.
This is for engine protection, not cleaning though! See post below.
N = R* x fp x ne x fl x fi x fc x L
Re: Marvel mystery oil vs Rislone engine treatment opinions [Re: Toh1] #4937284 11/27/18 10:57 PM
O
Onetor Offline
O
Several years ago, Dave at Redline recommended people with sludge/dirty engines to run Penn Ultra a couple times before using Redline. The group V esters in Redline are great cleaners. I would run Ultra for a couple short oil intervals. Kreen is also great, but you don't want to remove too much sludge.at one time. Kreen is awesome!
I would get Kreen with a quality synthetic oil. Do you have any pics? We love before and after.
Re: Marvel mystery oil vs Rislone engine treatment opinions [Re: Onetor] #4937297 11/27/18 11:23 PM
T
Toh1 Offline OP
T
I am using high mileage oil for more than 100k. I am thinking if I go to no high mileage oil my can can leak oil so I don’t want to go to non high mileage oil like pennnzoil platinum ultra or any other non high mileage oil.kreen is very hard to find so I am looking for for easy to find but not damaging the engine like mmo or Rislone engine treatment etc?
Re: Marvel mystery oil vs Rislone engine treatment opinions [Re: Toh1] #4937322 11/28/18 12:40 AM
SubieRubyRoo Offline
Are you sure this isn't detonation? Lifters are generally noisy on startup, NOT acceleration when oil pressure is high and rising. Piston rings won't make a ticking noise either. I say start with a fuel system cleaner that also cleans the combustion chamber- preferably one with PEA like Techron or Gumout AIO. Those are also available at Walmart and seems much more logical than an oil-based problem for what you are describing. It would also explain why your use of PP did not help anything. JMHO
Re: Marvel mystery oil vs Rislone engine treatment opinions [Re: SubieRubyRoo] #4937393 11/28/18 06:05 AM
T
Toh1 Offline OP
T
Oh sorry when I started my car in the morning I have lifters noise. I am not sure if it detonation but never have check engine light come on. I just changed my oil yesterday so when oil is new it did not tick or lifters noise do you know what it can be ? I am using Techron or gumout complete fuel system cleaner from last 2 year every oil change.
Re: Marvel mystery oil vs Rislone engine treatment opinions [Re: Toh1] #4937398 11/28/18 06:26 AM
Maybe take a video of the sound, both with the hood open on a cold start, and one underway. Some detonation shouldn't thow a CEL, depending on your vehicle.
Re: Marvel mystery oil vs Rislone engine treatment opinions [Re: Toh1] #4937400 11/28/18 06:29 AM
B
BMWTurboDzl Offline
B
How many miles, type of engine and current weight of oil?
Seems like an oil pressure issue.
435i
Re: Marvel mystery oil vs Rislone engine treatment opinions [Re: Toh1] #4937413 11/28/18 06:42 AM
Donald Offline
Kreen. Auto-Rx. Don't limit yourself to Walmart shelf.
I am not sure a stuck ring makes any noise like a tick. But lifter certainly will.
You cannot fix everything with a pill. Maybe its time to diagnosis more. Check all the lifters, remove and soak or replace the one that is making the noise.
2015 Ford F250 w/Powerstroke
Page 1 of 4 1 2 3 4
