Buying another car of the same generation
by brages - 02/25/20 01:02 PM
Buying Tires on Amazon
by jcartwright99 - 02/25/20 12:52 PM
plated cylinder liners and sulphur
by alex_at - 02/25/20 12:31 PM
Have we reached the ceiling in improvents to PCMO?
by Speak2Mountain - 02/25/20 11:59 AM
International travel for pleasure
by Pew - 02/25/20 11:42 AM
maxi scooter - should i change the oil now?
by alex_at - 02/25/20 11:05 AM
Toyota NA vs Toyota Global...
by mv6845 - 02/25/20 10:11 AM
How to determine Group II, III or IV
by Drew7a - 02/25/20 09:41 AM
Pulling axle question
by supton - 02/25/20 07:50 AM
Sams Club gas
by dbvettez061 - 02/25/20 07:44 AM
2019 Ram Battery Issue
by NYEngineer - 02/25/20 06:00 AM
belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
BJD2020, ToyTaco2002, EarlT500, Newbie111, Boris_Be
70800 Registered Users
96 registered members (Astro_Guy, alex_at, ajchien, asleepz, b1amgm47, 1978elcamino, 9 invisible), 2,370 guests, and 23 spiders.
Topics301,909
Posts5,205,197
Members70,798
ZF lifeguard 6 Atf #4936965 11/27/18 05:01 PM
charmer37 Offline OP
Hello, Do anyone know the cheapest source to buy ZF lifeguard 6 transmission fluid? The car is a 2004 Bmw 525i with a ZF 6 speed transmission...Thanks
Re: ZF lifeguard 6 Atf [Re: charmer37] #4936996 11/27/18 05:25 PM
shanneba Offline
Turner Motorsports has it for ~$25 a liter.
https://www.turnermotorsport.com/p-12618-automatic-transmission-fluid-6-speed-m-13754-1-liter/
I would probably opt for Red Line D6 at $12.95 a quart.
https://www.redlineoil.com/d6-atf
2003 BMW 330Ci
2013 HD Sportster XL1200C
Re: ZF lifeguard 6 Atf [Re: charmer37] #4937009 11/27/18 05:50 PM
slacktide_bitog Offline
You can use Maxlife smile
Re: ZF lifeguard 6 Atf [Re: slacktide_bitog] #4937035 11/27/18 06:11 PM
dave1251 Offline
It is what I used for my ZF.
don't use.
Re: ZF lifeguard 6 Atf [Re: charmer37] #4937061 11/27/18 06:48 PM
I
Imp4 Offline
I
Just Google it and you can find several sources selling at ~$20/qt.
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: ZF lifeguard 6 Atf [Re: charmer37] #4937066 11/27/18 06:53 PM
rooflessVW Offline
I ran Dex VI + Lubegard Platinum with no issues in my 6HP.
"Zed's dead baby, Zed's dead."
Re: ZF lifeguard 6 Atf [Re: charmer37] #4937067 11/27/18 06:59 PM
The Critic Online Crying
Online Crying
This kit will have everything you need for a PROPER fluid/filter service on your ZF 6-speed:
https://www.thectsc.com/products/oil-change-kit-for-bmw-hyundai-187-61.html
6 bottles of fluid, a new oil pan (the filter is built into the pan), new one-time use bolts, new sealing sleeve and a new fill plug.
2011 Toyota Prius 1.8L - 206K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 144K - Valvoline Premium Blue Restore 10W-30
Re: ZF lifeguard 6 Atf [Re: charmer37] #4937126 11/27/18 08:05 PM
W
working_title Offline
W
I've had Pentosin ATF1 in mine for the last 12,000 miles with no issues. I would have tried maxlife, but from the research I did the viscosity of the Pentosin was closer to lifeguard 6.
'15 F150 3.5 Ecoboost Havoline Pro DS 5w-30
'13 335iX (N55) Castrol 0w-40
'10 135i (N54) Castrol 0w-40
Re: ZF lifeguard 6 Atf [Re: charmer37] #4937134 11/27/18 08:11 PM
Many choices to choose from, Reading a few posts from another forum some have used Mercon SP successfully?
Re: ZF lifeguard 6 Atf [Re: slacktide_bitog] #4937139 11/27/18 08:13 PM
Maxlife works in ZF 6 speed transmissions?
Re: ZF lifeguard 6 Atf [Re: charmer37] #4937141 11/27/18 08:16 PM
Online Crying
According to slacktide_bitog (and some other folks on here), all stepped-gear automatics should be filled with Maxlife or the cheapest available "synthetic" universal ATF. Supposedly, there is no difference in ATF specs and it is all the same stuff....
Re: ZF lifeguard 6 Atf [Re: charmer37] #4937170 11/27/18 08:42 PM
bdcardinal Online Content
Online Content
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: ZF lifeguard 6 Atf [Re: The Critic] #4937205 11/27/18 09:12 PM
dave1251 Offline
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4547086/1
https://bobistheoilguy.com/forums/ubbthreads.php/topics/4390806/'Broad_Spectrum'_ATF,_how_does#Post4390806
https://www.bobistheoilguy.com/forums/ubbthreads.php/ubb/showflat/Number/4235914/Searchpage/3/Main/260972/Words/%2BMaxlife+%2B/Search/true/re-mixing-dexron-fluids#Post4235914
https://www.e90post.com/forums/showthread.php?t=1238331#post19588570
don't use.
Re: ZF lifeguard 6 Atf [Re: charmer37] #4937262 11/27/18 10:21 PM
Here is Valvoline's PDS for Maxlife ATF thumbsup
Re: ZF lifeguard 6 Atf [Re: charmer37] #4937276 11/27/18 10:41 PM
E
edyvw Offline
E
Yes it does. But take into consideration that ZF6 is true synthetic gear oil. It is expensive, but IMO it is worth.
Unless you are doing flush (which you should not) use ZF6 so you do not mix oils. It is transmission oil and you are not changing it often.
11' BMW 328i xDrive 6MT (BMW TPT 5W30+OE filter)
11' VW Tiguan 2.0T (Castrol 0W30+OE filter)
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
