Kendall nitro 70
by Bullwinkle007. 01/19/19 11:11 PM
Dexron HP
by Snagglefoot. 01/19/19 11:11 PM
Ruger American 22 Mag
by TiredTrucker. 01/19/19 11:06 PM
Prestone Dex Cool vs Carquest Dexcool
by A_User55555. 01/19/19 11:05 PM
FRAM end cap differences EG and TG vs XG
by wemay. 01/19/19 09:25 PM
Valvoline modern Engine
by Pinoak. 01/19/19 09:02 PM
30 Vintage Photos
by StevieC. 01/19/19 08:23 PM
Low mileage, when to change oil?
by Metfanant. 01/19/19 08:05 PM
Filter with bypass when OEM has built-in bypass
by rubberchicken. 01/19/19 07:43 PM
Barrett Jackson 2019 Pics
by Nick1994. 01/19/19 05:41 PM
What do y'all do with old car parts?
by qdeezie. 01/19/19 05:11 PM
Diagnosing catalytic converters.
by Tlhfirelion. 01/19/19 04:20 PM
Oil recommendations for GM Vortec 8100
by Dudemanmaximus. 01/19/19 04:14 PM
Leaf Spring Questions- Lots of Questions
by George7941. 01/19/19 04:02 PM
Am I being out of line?
by Chris142. 01/19/19 04:00 PM
Some good modern rock songs
by 53' Stude. 01/19/19 03:51 PM
06 Pathfinder O2 sensor voltage sensor 1
by Bluestream. 01/19/19 03:50 PM
Honda Blue Coolants
by redhat. 01/19/19 03:49 PM
dougway, Jetsfan421, Fordman420, 72sbc, ejmiller
66982 Registered Users
56 registered members (A_User55555, bbhero, 53' Stude, ammolab, AnthemBassMan, 3 invisible), 1,203 guests, and 36 spiders.
Topics296,863
Posts4,960,348
Members66,982
Most Online2,688
Jan 19th, 2019
Page 2 of 2 1 2
Re: 2018 F150-5.0V8 Kendall GT1 5W20 6030 miles [Re: dnewton3] #4937936
11/28/18 02:59 PM
11/28/18 02:59 PM
LA (Lower Alabama)
doyall Offline
doyall  Offline
LA (Lower Alabama)
Originally Posted by dnewton3
...Youtube again ... there's a way to defeat the auto S/S function by adding a jumper in the switch. Keeps you from having to deactivate every time.
https://www.youtube.com/results?search_query=ford+auto+start+stop+system+defeat+f150
everything from changing the programming to easy hard-wire jumpers
Suggestions on the truck forums are that the jumper method on 2018's will result in an error display. Posters also say using Forscan to reprogram will disable the Battery Management System.
Re: 2018 F150-5.0V8 Kendall GT1 5W20 6030 miles [Re: doyall] #4938163
11/28/18 07:26 PM
11/28/18 07:26 PM
USA
AITG Offline OP
AITG  Offline OP
USA
Originally Posted by doyall
Originally Posted by AITG
...The oil pan capacity is allegedly 9.9 quarts. ...
Better check your manual before you dump 10 quarts in it. My '18 5.0L specs 8.8 quarts.
You're right. Any time I try to do things from memory I'm reminded why I always told apprentices to look it up.
The answer to 80% of BITOG questions: Read the book, follow directions.
Changing oil is not maintenance. Maintenance is the science of inspecting equipment to find and fix things before they break.
Re: 2018 F150-5.0V8 Kendall GT1 5W20 6030 miles [Re: AITG] #4938225
11/28/18 08:35 PM
11/28/18 08:35 PM
upstate NY
dustyroads Offline
dustyroads  Offline
upstate NY
Well, capacity went up about a quart over my '13 anyway. Thanks guys.
2013 F150 XLT 5.0 4X4 104k miles
Edge 5W-30 / Fram 10575
Re: 2018 F150-5.0V8 Kendall GT1 5W20 6030 miles [Re: doyall] #4938531
11/29/18 07:30 AM
11/29/18 07:30 AM
Edmonton, Alberta, Canada
advocate Offline
advocate  Offline
What I've done on mine to disable the start/stop system is simple and it works, no errors or anything. There is a small two wire connection off of the battery, if you unplug that it will turn the system off. Many have done it, no ill effects so far. Mine has been off for 3-4 months now.
Re: 2018 F150-5.0V8 Kendall GT1 5W20 6030 miles [Re: advocate] #4938588
11/29/18 08:40 AM
11/29/18 08:40 AM
LA (Lower Alabama)
doyall Offline
doyall  Offline
LA (Lower Alabama)
That disables the Battery Management System as well. It apparently dictates the charging algorithm, perhaps other things. Some on the truck forums suggest disabling the BMS is a good thing but I have yet to be convinced taking into consideration an AGM battery.
Re: 2018 F150-5.0V8 Kendall GT1 5W20 6030 miles [Re: advocate] #4971751
01/06/19 08:55 PM
01/06/19 08:55 PM
USA
AITG Offline OP
AITG  Offline OP
USA
There is a tsb for harsh shifting. Take it to the dealer and they will reflash the pcm/tcm and it will shift smooth as butter every shift. Mine is a lot better since I’ve done it. But if you are modified maybe talk to your tuner and have them sort it out.
Update: as the weather got colder, shifting became completely unacceptable. Everything from violent 1-2 shifts that felt like the driveshaft snapped to hanging in first gear to dropping into neutral briefly between 1 and 2. The dealer did the update flash and it is now acceptable. It's still not like the previous 6 speed but I can live with it.
Re: 2018 F150-5.0V8 Kendall GT1 5W20 6030 miles [Re: AITG] #4971953
01/07/19 04:56 AM
01/07/19 04:56 AM
Indianapolis, IN
dnewton3 Offline
dnewton3  Offline
Indianapolis, IN
We got the 6R100 Torqshift G (upgraded 6R80) when the 10-spd came out in the F150. They shifted the production capacity of the 6-spd to gasser F250s when the 10-spd hit your market. The 6R100 is a sweet tranny overall.
Those of us driving the "new" 6.2L F250 trucks thank you for your donation!
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: 2018 F150-5.0V8 Kendall GT1 5W20 6030 miles [Re: dnewton3] #4972535
01/07/19 06:24 PM
01/07/19 06:24 PM
USA
AITG Offline OP
AITG  Offline OP
USA
I have a 2017 F53 chassis with the 6.8 V10 and a 6R140 transmission. The 6R140 shift quality is on a par with an Allison. Unfortunately, neither one is available in a pick up.
Re: 2018 F150-5.0V8 Kendall GT1 5W20 6030 miles [Re: AITG] #4973818
01/09/19 01:09 AM
01/09/19 01:09 AM
San Antonio, Texas
AdRock Offline
AdRock  Offline
San Antonio, Texas
To stop the AutoStart/stop I bought this. Not exactly cheap but now it stays off unless I press the button to turn it back on.
https://www.autostopeliminator.com/store/c2/2015-2019_Ford_F-150.html
2018 Ford F150 STX Crew Cab 5.0
2002 Ford Mustang GT 4.6
2016 Ford Escape 2.4
Page 2 of 2 1 2
