Kendall nitro 70
by Bullwinkle007. 01/19/19 11:11 PM
Dexron HP
by Snagglefoot. 01/19/19 11:11 PM
Ruger American 22 Mag
by TiredTrucker. 01/19/19 11:06 PM
Prestone Dex Cool vs Carquest Dexcool
by A_User55555. 01/19/19 11:05 PM
FRAM end cap differences EG and TG vs XG
by wemay. 01/19/19 09:25 PM
Valvoline modern Engine
by Pinoak. 01/19/19 09:02 PM
30 Vintage Photos
by StevieC. 01/19/19 08:23 PM
Low mileage, when to change oil?
by Metfanant. 01/19/19 08:05 PM
Filter with bypass when OEM has built-in bypass
by rubberchicken. 01/19/19 07:43 PM
Barrett Jackson 2019 Pics
by Nick1994. 01/19/19 05:41 PM
What do y'all do with old car parts?
by qdeezie. 01/19/19 05:11 PM
Diagnosing catalytic converters.
by Tlhfirelion. 01/19/19 04:20 PM
Oil recommendations for GM Vortec 8100
by Dudemanmaximus. 01/19/19 04:14 PM
Leaf Spring Questions- Lots of Questions
by George7941. 01/19/19 04:02 PM
Am I being out of line?
by Chris142. 01/19/19 04:00 PM
Some good modern rock songs
by 53' Stude. 01/19/19 03:51 PM
06 Pathfinder O2 sensor voltage sensor 1
by Bluestream. 01/19/19 03:50 PM
Honda Blue Coolants
by redhat. 01/19/19 03:49 PM
dougway, Jetsfan421, Fordman420, 72sbc, ejmiller
66982 Registered Users
56 registered members (A_User55555, bbhero, 53' Stude, ammolab, AnthemBassMan, 3 invisible), 1,203 guests, and 36 spiders.
Topics296,863
Posts4,960,348
Members66,982
Most Online2,688
Jan 19th, 2019
2018 F150-5.0V8 Kendall GT1 5W20 6030 miles #4933397
11/23/18 08:00 PM
11/23/18 08:00 PM
USA
AITG Offline OP
AITG  Offline OP
USA
Code
Unit mi.
    3020   9050
Oil mi:
    3020   6030
Fe    29     15
Cr     1      0
Ni     1      0
Al     4      3
Cu    29      7
Pb     1      0
Sn     0      0
Cd     0      0
Ag     0      0
V      0      0
Si    37     18
Na    10      3
K     14      4
Ti     0     94
Mo    70     21
Sb     0      0
Mn    17      6
Li     0      0
B    164     68
Mg    12     12
Ca  2051   2425
Ba     1      0
P    687    739
Zn   751    834
Fuel% <1    3.1
Soot <.1    <.1
Water<.1    <.1
Vis100c 7.3 6.7
No make up oil was added and the IOLM was at 40%.
This is a modified DI engine (2 injectors per cylinder) so the fuel dilution doesn't surprise me. Wear metals are really low for only the second change since new. I agree with Dnewton3 that fuel dilution is an occurrence rather than a problem at this point. However, I am low on 5W-20 oil but have a good supply of 5W-30 for my 6.8 V10 so I may try the 5W-30 next change. I don't see wear problems in the Ford DI UOAs here but the cam phasers may be happier long term on 5W30.
The truck is a step up from my 2011 in nearly every way. The only thing I don't like is the transmission. The 10 speed was a joint effort between GM and Ford. GM must have done gears 1 thru 5 and Ford did the rest. Cold shifts act like the drive shaft is going to fall out. Once it hits 6, it's flawless. Warm, everything is happy.
The answer to 80% of BITOG questions: Read the book, follow directions.
Changing oil is not maintenance. Maintenance is the science of inspecting equipment to find and fix things before they break.
Re: 2018 F150-5.0V8 Kendall GT1 5W20 6030 miles [Re: AITG] #4933606
11/24/18 06:01 AM
11/24/18 06:01 AM
Northern Ontario, Canada
Danno Offline
Danno  Offline
Engine breaking in nicely.
2016 Sorento SX V6 AWD
2015 KIA RIO SX
2010 Mazda 3 2.0L
2009 Venza V6 AWD
2013 Sonata 2.4L RIP in write-off crash
Re: 2018 F150-5.0V8 Kendall GT1 5W20 6030 miles [Re: AITG] #4933678
11/24/18 08:13 AM
11/24/18 08:13 AM
Edmonton, Alberta, Canada
advocate Offline
advocate  Offline
What did you modify on your 5.0?
There is a tsb for harsh shifting. Take it to the dealer and they will reflash the pcm/tcm and it will shift smooth as butter every shift. Mine is a lot better since I’ve done it. But if you are modified maybe talk to your tuner and have them sort it out.
Nice report. The low viscosity worries me some but it doesn’t seem to be affecting anything. I’m using Pennzoil Ultra Platinum 0w-20 with a Fram Ultra and I’m following the iolm. First change was around 6k and it seems to be tracking about the same for me using the monitor.
Re: 2018 F150-5.0V8 Kendall GT1 5W20 6030 miles [Re: AITG] #4933799
11/24/18 09:53 AM
11/24/18 09:53 AM
USA
AITG Offline OP
AITG  Offline OP
USA
By "modified" I am referring to the dual injection setup. I should have referred to it as Gen 2.
Re: 2018 F150-5.0V8 Kendall GT1 5W20 6030 miles [Re: AITG] #4933860
11/24/18 10:46 AM
11/24/18 10:46 AM
LA (Lower Alabama)
doyall Offline
doyall  Offline
LA (Lower Alabama)
The moderate dilution on these engines causing lower viscosity is why I am currently doing a 50/50 mix of 5W-20 and 5W-30. I may ultimately go to 100% 5W-30 if mine gets out of hand.
Re: 2018 F150-5.0V8 Kendall GT1 5W20 6030 miles [Re: AITG] #4933863
11/24/18 10:51 AM
11/24/18 10:51 AM
advocate Offline
advocate  Offline
Ok. So it’s actually a stock gen 3 coyote then. They all have dual injection now. You are on the right path. Wear numbers are low and declining each change. Nice job. Keep the uoa’s coming.
Re: 2018 F150-5.0V8 Kendall GT1 5W20 6030 miles [Re: AITG] #4935204
11/25/18 08:06 PM
11/25/18 08:06 PM
Indianapolis, IN
dnewton3 Offline
dnewton3  Offline
Indianapolis, IN
Looks good; really good for only having about 9k miles on it. Break in will continue to come down I suspect.
I will enjoy seeing the UOAs as this engine ages.
Continue on!
Interesting about the 10spd trans. Hope it does not cause issues long term.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: 2018 F150-5.0V8 Kendall GT1 5W20 6030 miles [Re: doyall] #4936156
11/26/18 07:25 PM
11/26/18 07:25 PM
Maricopa, Arizona
dave1251 Online happy
dave1251  Online Happy
Maricopa, Arizona
It has been tested with a 5W20. If dillution is a issue Ford would have recommended 5W30. A 100C viscosity of 7 is still a 20 grade.
don't use.
Re: 2018 F150-5.0V8 Kendall GT1 5W20 6030 miles [Re: AITG] #4936550
11/27/18 08:46 AM
11/27/18 08:46 AM
upstate NY
dustyroads Offline
dustyroads  Offline
upstate NY
Looks good for a new engine, especially the factory fill. I'm a little surprised about the fuel dilution, being a DPFI system. I thought maybe they would lean heavy on the port injection unless there was a need for a lot of power. Do you have a lead foot? grin Obviously I don't know what strategy the engineers are using, but I didn't expect to see the fuel in these.
Thanks for posting. If I get a new 5.0, I have something to go on with your data. Does it still take (about) 8 quarts or have they bumped up to a 10 quart capacity (like the Mustang)?
2013 F150 XLT 5.0 4X4 104k miles
Edge 5W-30 / Fram 10575
Re: 2018 F150-5.0V8 Kendall GT1 5W20 6030 miles [Re: dave1251] #4936723
11/27/18 12:01 PM
11/27/18 12:01 PM
LA (Lower Alabama)
doyall Offline
doyall  Offline
LA (Lower Alabama)
Originally Posted by dave1251
[... If dillution is a issue Ford would have recommended 5W30. ...
You sure do have a lot of faith in Ford. Wish I could get to that level.
I would not necessarily call moderate dilution (2 -3%) an "issue", but depending on operational/environmental parameters I could see an issue in the making.
Re: 2018 F150-5.0V8 Kendall GT1 5W20 6030 miles [Re: AITG] #4936731
11/27/18 12:11 PM
11/27/18 12:11 PM
Indianapolis, IN
dnewton3 Offline
dnewton3  Offline
Indianapolis, IN
Does this "new" engine iteration have a HP fuel pump similar to the 3.5L EB? Mounted in the valve area and driven off a lobe?
Re: 2018 F150-5.0V8 Kendall GT1 5W20 6030 miles [Re: AITG] #4936775
11/27/18 01:06 PM
11/27/18 01:06 PM
USA
AITG Offline OP
AITG  Offline OP
USA
Good question...I have no idea. The 2011 5.0 was a clean installation. The 2018 has vacuum tubes running over the top of the engine: tees, elbows, clutter. I do notice that opening the driver's door when the engine is cold triggers something that sounds like an electric fuel pump. It clicks six times but we haven't tracked it down yet.
Where do I look for the HP pump? I envision something like a small block Chevy crammed against the block in an inaccessible location.
There is a secondary air induction that you can hear closing when you close the throttle, I assume that's located in the intake somewhere as well. Also, I have the delightful auto start/stop. My routine is "start truck, shut off s/s, put in gear".
There's a lot of complexity added for an incremental gain in fuel economy. Fortunately I plan on never doing engine work on this thing.
Re: 2018 F150-5.0V8 Kendall GT1 5W20 6030 miles [Re: dustyroads] #4936784
11/27/18 01:15 PM
11/27/18 01:15 PM
USA
AITG Offline OP
AITG  Offline OP
USA
I do occasionally stand on it but for the most part it isn't pushed hard. My hard acceleration is usually passing on two lane roads...typically 45 or 50 mph up to 70 and back down.
The oil pan capacity is allegedly 9.9 quarts. Measuring the exact fill, running it for five minutes and letting it sit overnight results in the dipstick showing it's down about a half quart. I will probably just add 10 next time.
Re: 2018 F150-5.0V8 Kendall GT1 5W20 6030 miles [Re: AITG] #4937045
11/27/18 06:29 PM
11/27/18 06:29 PM
LA (Lower Alabama)
doyall Offline
doyall  Offline
LA (Lower Alabama)
Originally Posted by AITG
...The oil pan capacity is allegedly 9.9 quarts. ...
Better check your manual before you dump 10 quarts in it. My '18 5.0L specs 8.8 quarts.
Re: 2018 F150-5.0V8 Kendall GT1 5W20 6030 miles [Re: AITG] #4937664
11/28/18 11:02 AM
11/28/18 11:02 AM
Indianapolis, IN
dnewton3 Offline
dnewton3  Offline
Indianapolis, IN
... Where do I look for the HP pump? I envision something like a small block Chevy crammed against the block in an inaccessible location.
Well the ones on the 3.5EB engines are mounted on the rear of the driver side valve cover.
The 1.0EB engines have it on the valve cover as well.
This is because those HPFP are driven by a cam lobe.
See this link for several examples:
https://www.youtube.com/results?search_query=ford+3.5+ecoboost+high+pressure+fuel+pump
... Also, I have the delightful auto start/stop. My routine is "start truck, shut off s/s, put in gear".
Youtube again ... there's a way to defeat the auto S/S function by adding a jumper in the switch. Keeps you from having to deactivate every time.
https://www.youtube.com/results?search_query=ford+auto+start+stop+system+defeat+f150
everything from changing the programming to easy hard-wire jumpers
