Originally Posted By: grndslm
Not in your budget??
I'll share with you perhaps my favorite eBike build of all time, mostly because of its simplicity and cleanliness.
http://www.youtube.com/watch?v=WsbOD09doRI
I am more than likely going to mimic this setup once I get a hold more on controllers and such.... and depending on where I want to go with it after actually experiencing it for myself, I could add a shift kit to it, but I like to keep things as cheap as possible.
An eBike build has like 4 components... motor (the motor this guy uses is pretty small, probly $60 or so), controller (not sure about this stuff yet, but probly $50), throttle (just a potentiometer, haven't looked.. but a "thumb lever" throttle would be best if possible... can't be more than $50), and batteries (might as well spend all your money on the best lithium polymer batteries money can buy. Oh yea, and a charger... I guess you'd have to pay around $30 for it and a few extra bucks for an adapter & some wiring to somehow connect the charger to the batteries.
So we're talking $200 all day long, and you add the batteries. There's no way in hail that lithium polymer batteries cost more than $800.
Good post, but if you aren't wanting to DIY, it costs, and I'll wager the components are slightly more, but not much for the basics you list for decent stuff. A good controller is around $150 and so on.
Sure 36V batteries at 10Ah aren't so bad $, but look at 48V 20Ah and yes they are over $1000 delivered. Those cheaper kits always have garbage batteries. The key here remains getting good battery prices down.
