Originally Posted by StevieC
The way folks talk about API around here you would think they were gods. They aren't.
That seems a tad hyperbolic. I don't recall anybody on this board referring to the API as "godlike". They define a minimum level of oil quality, which is, for many manufacturers, all that is required for their applications.
Their minimum standard is too low and there can be far better oils out there whether API licensed or not. The Dexos 1 Gen 2 specification is needed in certain applications but can benefit all applications so why the API wouldn't step up and make that the minimum to eliminate confusion and to benefit even those engines not requiring it, is beyond me.
Yet Toyota, Honda, Subaru, Nissan...etc disagree with you here. If they felt the standard was too low, they would either require something more extensive like an ACEA designation or, they would develop their own approval. Since they've done neither, we can safely conclude that for many applications, the API standard is sufficient.
The API isn't making Dexos 1 Gen 2 the standard because that's GM's standard. Just like they they don't use Porsche A40 or BMW LL-01.
While it is certainly possible to best the API test requirements with a lubricant that doesn't carry the API rating, it is also quite possible to not meet it. That's one of the purposes of the PQIA.
Especially when price doesn't seem to be a factor (D1G2 oils are no more expensive when compared to SN rated only synthetics) and considering most oils are D1G2 rated now anyway and that it encompasses the SN requirements anyway.
You've answered your own question there. The proliferation of GM vehicles on the road makes it illogical for a major blender to not carry the Dexos approval. Because of this, they are all cost-competitive with each other. On the other hand, AMSOIL charges a premium for their product, yet are not paying the Dexos licensing fee, simply stating that they run the protocol and best the performance metrics
Further why was it the formulators/blenders that figured out that lowering calcium in oils is a fix to safeguard against LSPI and not the API requiring it? We have had GDI/TGDI engines for quite a while now and folks like M1 changed this some time ago yet mum's the word from the API?
Firstly, Toyota was one of the companies that discovered LSPI:
https://www.sae.org/publications/technical-papers/content/2014-01-2785/
Secondly, the API standards are slow to evolve and are often based on evolutions and discoveries in OEM testing. So, while LSPI is only now being addressed in SN Plus despite Mobil and OEM's being aware of it for some time prior, we also didn't see Toyota develop an oil standard to deal with it either.
I stand they are useless aside from protecting Joe consumer from shelf oils at the dollar store that shouldn't be used in anything.
Their required "minimums" are too low and better options are out there and better specs that supersede theirs at no additional cost.
Well, as I noted above, the Japanese OEM's don't seem to agree with you.
