Credit Karma
by aquariuscsm - 10/22/19 01:20 PM
Does Fuel Dilution Leave Oil After Cause Resolved?
by LoneRanger - 10/22/19 01:11 PM
How do you select tires?
by ZZman - 10/22/19 12:12 PM
Shell TF-0870
by rooflessVW - 10/22/19 12:07 PM
Reverse tire look up?
by tiredguy - 10/22/19 11:35 AM
Oil consuming 2004 Mercury Marauder
by 2013ecof150 - 10/22/19 11:09 AM
2015 Triumph Trophy SE - Castrol 10W40
by Rick505 - 10/22/19 11:08 AM
need a mini van/suv for my son 10k
by BeerCan - 10/22/19 10:52 AM
Propene, polymer with ethene use in motor oil
by DrDanger - 10/22/19 10:29 AM
Wax recommendations
by dawgn86 - 10/22/19 09:46 AM
Oil and Filter Advice
by dawgn86 - 10/22/19 09:44 AM
Lift Master Remote RE-Programming
by Gebo - 10/22/19 09:10 AM
My '88 Daytona
by IronMaidenRules - 10/22/19 09:08 AM
QSUD and cleaning?
by irv - 10/22/19 08:56 AM
New 2019 Toyota Highlander first oil change
by thooks - 10/22/19 07:50 AM
2019 Golf R
by wings&wheels - 10/22/19 06:47 AM
My latest battery load test
by Char Baby - 10/22/19 05:18 AM
MB Loctite 5970
by The Critic - 10/22/19 01:18 AM
Amazon Special on Lubegard LXE
by Marco620 - 10/21/19 11:42 PM
TV_Viewer2, Finner, blimo, Haiducek, NoRegrets
69642 Registered Users
107 registered members (2013ecof150, 28oz, 97f150, 14Accent, 53' Stude, 6 invisible), 2,256 guests, and 28 spiders.
Topics296,329
Posts5,095,735
Members69,642
Most Online3,532
Jul 30th, 2019
Page 2 of 2 1 2
Re: Can I safely use STP Oil Treatment in my car [Re: cwilliamsws6] #4928610 11/19/18 09:17 AM
B
BrocLuno Offline
B
STP is CALCIUM LONG-CHAIN ALKYLPHENATE SULPHIDE in a mineral oil base. It's the basis for an old school VII. It has an inverse temperature coefficient. MSDS here. Roughly the same chemistry as Lucas Oil Stabilizer ...
It prolly won't hurt anything, but I doubt it will help. With that many miles I suspect that things are more gummed up than needing thicker oil ... First thing I'd do is dump a whole can of BG109 (EPR) in there and drive it for 100 miles and see how it sounds/runs. Change the oil to a full syn (SuperTech High Mileage Synthetic OK) and use a factory filter (or Napa Gold/WIX) and another full can of BG109. Drive it to the next oil change.
The tick should be gone smile
Re: Can I safely use STP Oil Treatment in my car [Re: cwilliamsws6] #4928621 11/19/18 09:23 AM
K
KCJeep Offline
K
If you use STP, slowly pour it into a hot, running engine.
We used STP in everything when I was a kid, and more recently I played with it in the Jeep. Won't hurt anything, and can be helpful if you find yourself wanting or needing to thicken your oil up a bit without doing a whole OCI.
2018 VW Passat GT VR6 - 17k - Castrol Pro OE 5w40 - VW OEM filter
2012 KIA Sedona 103k - Valvoline Maxlife 5w30
2012 VW Tiguan 102k - Castrol 0w40
2004 Jeep Grand Cherokee, gone but not forgotten.
Re: Can I safely use STP Oil Treatment in my car [Re: cwilliamsws6] #4928640 11/19/18 09:41 AM
cwilliamsws6 Offline OP
Will do, thanks for the tip KC
2002 Trans-Am WS6, auto + LS6 "Me Fastr" (sold)
2007 Honda CR-V LX "The Linoleum Falcon" 210K miles
Carquest conventional 5W-20, Carquest Premium 84356 filter
"Bad decisions make good stories."
Re: Can I safely use STP Oil Treatment in my car [Re: cwilliamsws6] #4928647 11/19/18 09:47 AM
CT8 Online Content
Online Content
You need to get a professional opinion. It is hard to diagnose noise over the net.
2015 F150 2.7
2018 F350 6.2
Re: Can I safely use STP Oil Treatment in my car [Re: cwilliamsws6] #4928724 11/19/18 11:06 AM
T
thrace Offline
T
Like 2nd poster says, depends whether valve lash is correct. Crv does not have hydraulic lifters and could need valve adjustment at 200k mi if not yet done. Too tight, especially exhaust valve, can burn valve without too much noise.
Re: Can I safely use STP Oil Treatment in my car [Re: ragtoplvr] #4928892 11/19/18 01:09 PM
dave1251 Offline
Originally Posted by ragtoplvr
I have a 91 dodge Dakota 4cy 5 speed that will not quit. It does use oil. If you run anything other than 5/10W30 in it there is a lifter tick that last for a while after starting. If you try to use XW40 or HM oil in it to cut the consumption the lifters DO NOT like it. But 10W30 and STP 4CY , no tick, oil consumption cut in half. It is NOT sitting on the bottom of the pan. It is doing something. I may be one of very few, but for me it works
Rod
All it did was thicken the viscosity and weakened the additve pack.
don't use.
Re: Can I safely use STP Oil Treatment in my car [Re: cwilliamsws6] #5112365 05/22/19 12:32 PM
A
addyguy Offline
A
It's not a miracle cure, but it CAN quiet down noisy engines. I just added it to my Soul that has a clattery valvetrain at start up. Dulled the noise a bit, but is still there.
2010 Kia Soul 2U - 2.0L I-4, auto; 146k miles.
Castrol GTX HM 5W-30, STP blue bottle; Fram TG 9688.
2009 Pontiac G5 - 2.2 I-4, auto, 121k miles.
Oil/filter TBD
Re: Can I safely use STP Oil Treatment in my car [Re: cwilliamsws6] #5113046 05/23/19 03:02 AM
Marco620 Offline
Would be better off w liquimoly Motor Oil Saver.
15' Civic 1.8 i-vtec 280,000 mi Redline 0w20, BP CVT Fluid,Redline Si-1
Doberman Whisperer!
Redline Oil,Honda,Doberman,CZ & SONY Aficionado
Re: Can I safely use STP Oil Treatment in my car [Re: cwilliamsws6] #5118719 05/28/19 09:23 PM
dave1251 Offline
If you want to thicken oil just use a thicker oil.
don't use.
Re: Can I safely use STP Oil Treatment in my car [Re: cwilliamsws6] #5118869 05/29/19 05:15 AM
demarpaint Offline
I'd try a HM 5w20 or 5W30 and a different filter. If that doesn't help Schaeffers #132 will accomplish what you're trying to do, and it is considered a much better product than STP by many on Bitog.
God Bless Our Troops
Re: Can I safely use STP Oil Treatment in my car [Re: cwilliamsws6] #5118882 05/29/19 05:42 AM
J
JC1 Offline
J
As others have said, skip the STP. I would try a different oil. What is currently in the sump now?
2015 Grand Caravan SXT Plus 5w-30 Valvoline White Bottle/Fram Ultra Filter
1997 Honda Civic CX 5w-30 Shell Conventional/Fram Ultra Filter
Re: Can I safely use STP Oil Treatment in my car [Re: JC1] #5121385 05/31/19 02:40 PM
I'm just using Carquest conventional 5w-20. Black jug.
Re: Can I safely use STP Oil Treatment in my car [Re: cwilliamsws6] #5125482 06/04/19 10:52 PM
dave1251 Offline
I would try a 40 grade oil.
don't use.
Re: Can I safely use STP Oil Treatment in my car [Re: dave1251] #5125720 06/05/19 09:02 AM
B
Bonz Offline
B
I agree, put a heavier weight oil in there. STP’s not doing any appreciable thickening of the 5W20 towards the goal you have. In days gone by it was additional zinc the STP provided. I don’t believe it provides enough ppm per volume to do anything worthwhile in terms of that anymore. Pure feel good for the owner, car doesn’t know.
Re: Can I safely use STP Oil Treatment in my car [Re: cwilliamsws6] #5148469 07/01/19 09:45 AM
H
Hoot_r Offline
H
I'm currently running 5w-20 which is what is specified. Looking at the old maintenance logs in the owners' manual, the previous owner used 5W-30 a lot. Interesting
There may well have been a reason why the previous owner chose that weight. Go back to that weight and note any changes -- is the sound better, or worse?
2020 Kia Soul LX, 2.0L Atkinson-cycle I-4 (Nu)
Castrol Magnatec FS 5W30, OEM Filter
Page 2 of 2 1 2
