Best Shell/Pennzoil is ?
by Dragon44. 06/16/19 01:22 AM
Getting the the boat ready for summer holidays
by Snagglefoot. 06/15/19 10:57 PM
Fram: With Even More Protection
by TheLawnRanger. 06/15/19 10:01 PM
More kid pictures
by Marco620. 06/15/19 09:34 PM
Pennzoil Platinum 5W30 : Does It Hold Up ?
by ChrisD46. 06/15/19 09:16 PM
Filter type for New Holland TC24DA
by jayjr1105. 06/15/19 09:13 PM
Subaru OEM Cut Open (2014 Crosstrek) - 8,000 kms
by mcwilly. 06/15/19 08:30 PM
Fram CA9997
by mcwilly. 06/15/19 08:23 PM
Snoopy found...
by Shannow. 06/15/19 08:15 PM
Tire buying in 5min Sam’s Club
by Patrick0525. 06/15/19 08:11 PM
AR-style rifle -- suggestions
by 92saturnsl2. 06/15/19 08:07 PM
To oil or not oil OPE foam pre-filters
by 92saturnsl2. 06/15/19 07:54 PM
Any Harvest King High mileage VOA'S?
by 53' Stude. 06/15/19 07:24 PM
Champion AGM Batteries
by The Critic. 06/15/19 06:52 PM
Redneck Battery Recovery
by cwilliamsws6. 06/15/19 06:29 PM
Currently Using iPhone 6S...Should I Upgrade?
by john_pifer. 06/15/19 05:08 PM
Is it Router or Comcast?
by RW1. 06/15/19 05:01 PM
bagyoau, frank57, gheewala114, Rob_Jeff, BrianinTucson
68412 Registered Users
38 registered members (AndyB, BlueOvalFitter, Bighorn2500, chemman, bagyoau, 8 invisible), 636 guests, and 18 spiders.
Topics290,259
Posts4,987,225
Members68,412
Most Online2,967
Mar 10th, 2019
Can I safely use STP Oil Treatment in my car #4928364
11/18/18 11:39 PM
11/18/18 11:39 PM
Ohio
cwilliamsws6 Offline OP
Ohio
2007 Honda CR-V, 200,xxx miles and coming up on needing it's next oil change. The engine is a tad noisy now that it's colder out (tick tick tick) and I was wondering if STP oil treatment is safe to use being that it has variable valve timing. Thanks!
I'm 17 and I do my own oil changes and everything! smile
2007 Honda CR-V LX, 205K miles
Carquest conventional 5W-20
Carquest Premium 84356 filter
Re: Can I safely use STP Oil Treatment in my car [Re: cwilliamsws6] #4928367
11/18/18 11:46 PM
11/18/18 11:46 PM
San Diego, CA
Joenpb Offline
Joenpb  Offline
San Diego, CA
I wouldn't use it. Too thick and will likely just sit in the bottom of your oil pan. I'd go with a high mileage formula oil, good luck.
Re: Can I safely use STP Oil Treatment in my car [Re: cwilliamsws6] #4928376
11/19/18 12:00 AM
11/19/18 12:00 AM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
I'd try an OE filter first if you aren't using this, and then I would try a High Mileage oil like Valvoline Maxlife first.
'18 Caravan - 36k KM - AMSOIL SS 0w20, Fram Ultra, TC-W3 500:1
'06 Santa Fe - 535k KM (Retired)
There is no such thing as "lifetime" fluids! mad
Re: Can I safely use STP Oil Treatment in my car [Re: cwilliamsws6] #4928380
11/19/18 12:11 AM
11/19/18 12:11 AM
Phoenix, Arizona - USA
SirTanon Offline
SirTanon  Offline
Skip the STP treatment. If anything, I'd say maybe go a bit lighter weight.
2013 Nissan Altima SV - 2.5 liter/CVT - 113,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 65,000mi
2010 Ford Fusion - 274,000mi
Re: Can I safely use STP Oil Treatment in my car [Re: cwilliamsws6] #4928387
11/19/18 12:21 AM
11/19/18 12:21 AM
Toronto
PeterPolyol Offline
PeterPolyol  Offline
Toronto
K24 is no church mouse to begin with that's for sure. If your valve lash is in spec (noise is probably piston slap anyway) then I'd just live it with that little NVH issue.
There's no replacement...'scosity for natural viscosity
Re: Can I safely use STP Oil Treatment in my car [Re: cwilliamsws6] #4928432
11/19/18 02:36 AM
11/19/18 02:36 AM
PA
Gasbuggy Offline
Gasbuggy  Offline
PA
Won't hurt anything because it doesn't actually do anything.
Cadillac CTS-V 6.2L 10w30PP
Volvo P1800 5w30 Euro L
LR Series III 10w40 VWB
76' 300D Rotella T4
02 Yukon 10w30 PP
10 Charger Pursuit 5.7L
01 P71 with SAP
95 Accord - 386k. Mobil 2 RIP
Re: Can I safely use STP Oil Treatment in my car [Re: cwilliamsws6] #4928462
11/19/18 04:45 AM
11/19/18 04:45 AM
1/2 hr N.E. of Detroit
Triple_Se7en Offline
Rislone 16oz or 32oz bottle - not the Concentrate.
19 Hyundai SantaFe 2.4GDI Castrol Edge 5w30 / NAPA Mann-Hummel filter / 6oz Liqui-Moly Treatment
04 Colorado 3.5 Castrol Edge 0W40 Euro & K&N filter
03 Malibu 3.1 QS / Valv Syn 5w30 mix Fram EG filter
Re: Can I safely use STP Oil Treatment in my car [Re: cwilliamsws6] #4928490
11/19/18 05:53 AM
11/19/18 05:53 AM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
There are varying opinions on whether it works, but is it “safe”? Yes. It’s just overly expensive thick oil. It will completely disperse into your oil. Just warm your engine up before you pour it in. If this is a quick check before you change your oil, go ahead. The better way would be to change to a higher viscosity oil as it would have a better additive package. I don’t use the stuff but I have witnessed an engine get quieter as STP was added. That must have been a case of excessive wear in the lifters in an older engine. Report back to use on whether or not it made any difference. smile
If you want the job done right......do it yourself.
Re: Can I safely use STP Oil Treatment in my car [Re: cwilliamsws6] #4928491
11/19/18 05:55 AM
11/19/18 05:55 AM
NC
Vladiator Offline
Vladiator  Offline
NC
Skip the STP additive.
What oil are you running currently? Per owner's manual or something more viscous? If using a 10w30/10w40, then try a 5w30 Valvoline Maxlife, or any other synthetic blend 5w30 in High Mileage formula. If you are on conventional 5w30, then a synthetic blend 5w30 could definitely help with the cold noise.
P.S. If it was mine - I would run Mobil1 0w40 in it until the engine/tranny quits, or until it gets totalled/sold. 5k OCI with close eye on the oil level.
Re: Can I safely use STP Oil Treatment in my car [Re: cwilliamsws6] #4928493
11/19/18 05:59 AM
11/19/18 05:59 AM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
What grade of oil is recommended for your CR-V and what grade are you using? I believe it is 5W20
You're always going to get several different opinions here so, I'll add mine too.
Don't use STP or any other oil additive in your CR-V. Do in fact(if anything) use a thicker oil(not thinner). And what I mean by thinker is...
...if you're using a 5W20, change to a 5W30. I do agree with using a High Mileage Oil as they seem to run a tiny bit thicker in their specific grade. And again, I may use a 5W30 High Mileage oil which is still decent for winter use.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: Can I safely use STP Oil Treatment in my car [Re: cwilliamsws6] #4928584
11/19/18 08:40 AM
11/19/18 08:40 AM
Ohio
Ohio
I'm currently running 5w-20 which is what is specified. Looking at the old maintenance logs in the owners' manual, the previous owner used 5W-30 a lot. Interesting
Re: Can I safely use STP Oil Treatment in my car [Re: cwilliamsws6] #4928585
11/19/18 08:41 AM
11/19/18 08:41 AM
Texas
Bud Offline
Bud  Offline
Texas
Safely use it, yes. Will it do anything for you is another question. Try it if you want, but I agree with Char Baby.
2016 Honda Pilot EX-L with NAVI.....Mobil 1 0w20 AFE and Honda OEM Filter
Re: Can I safely use STP Oil Treatment in my car [Re: cwilliamsws6] #4928598
11/19/18 08:54 AM
11/19/18 08:54 AM
PimTac Offline
PimTac  Offline
I would pass on the additivesnd go with a HM oil like Valvoline Maxlife or the brand you prefer and in 5w30.
2017 Mazda CX5
Havoline Pro DS 0w20
Roki OEM filter.
Re: Can I safely use STP Oil Treatment in my car [Re: cwilliamsws6] #4928599
11/19/18 08:55 AM
11/19/18 08:55 AM
missouri
ragtoplvr Offline
ragtoplvr  Offline
missouri
I have a 91 dodge Dakota 4cy 5 speed that will not quit. It does use oil. If you run anything other than 5/10W30 in it there is a lifter tick that last for a while after starting. If you try to use XW40 or HM oil in it to cut the consumption the lifters DO NOT like it. But 10W30 and STP 4CY , no tick, oil consumption cut in half. It is NOT sitting on the bottom of the pan. It is doing something. I may be one of very few, but for me it works
Rod
Re: Can I safely use STP Oil Treatment in my car [Re: cwilliamsws6] #4928600
11/19/18 08:57 AM
11/19/18 08:57 AM
Ohio
Ohio
A gas station near me sells STP oil treatment for $1.50 for a 12 ounce bottle so I'll go ahead and try it. I'm honestly more curious than anything now of how good it'll work if it will at all. I'll definitely report back in a few days
