A lot of vehicles no longer have radiator drains, and the lower rad hose has to be disconnected to do a drain, Chev trucks being one example. In the case of Chev's the OEM spring type clamp is very robust. For those in this type of situation do you reuse the OEM clamp, or put on a screw clamp. What other makes have done away with radiator drain valves?
