PP 5W-20, 3000mi, '14 Kia Soul
by tc1446. 06/24/19 03:07 PM
Cheap powerfull filter magnet
by loneryder. 06/24/19 01:50 PM
New road tire time
by UG_Passat. 06/24/19 01:46 PM
Royal Purple 75W90 vs. Store Brand Synthetic
by WondrousBread. 06/24/19 12:50 PM
Jeep Renegade MTF Alternatives?
by Sunnyinhollister. 06/24/19 12:28 PM
Havoline 0W20 VI higher than 5w30 and 10w30?
by Whammo. 06/24/19 12:10 PM
New toy...19 Jetta GLI Autobahn
by CincyDavid. 06/24/19 12:00 PM
PCV Valve Cleaning Replacement ?
by ChrisD46. 06/24/19 11:54 AM
Honda cvt fluid change frequency?
by axxel6307. 06/24/19 11:09 AM
Lease - Gap Coverage
by coopns. 06/24/19 10:37 AM
Corner lot cutters
by BJD78. 06/24/19 09:44 AM
Think I killed my Briggs 190CC Free Mower
by Miller88. 06/24/19 09:14 AM
Service Pro oil any good?
by MileHigh18. 06/24/19 09:09 AM
Volvo S80.
by D1dad. 06/24/19 08:23 AM
Chain saw stopped oiling
by Chris142. 06/24/19 08:19 AM
List of oil filter that use coil spring
by MetalSlug. 06/24/19 07:50 AM
303 annoyance
by Gasbuggy. 06/24/19 04:39 AM
my K&N...
by dirtydannyd. 06/24/19 03:44 AM
ml98188, 84FSP, megavoyager, thaduke2003, Vitaliy
68474 Registered Users
96 registered members (1978elcamino, 2oldtommy, 69GTX, 53' Stude, 2015_PSD, 9 invisible), 2,412 guests, and 32 spiders.
Topics290,905
Posts4,995,040
Members68,474
Most Online2,967
Mar 10th, 2019
How to extract oil? #4884379
10/01/18 09:39 AM
10/01/18 09:39 AM
Australia
Spetz Offline OP
Spetz  Offline OP
Australia
Hi everyone,
I ordered a UOA kit that has a tube and a syringe to get the oil from the dipstick,
My questions are:
1. Does the oil need to be hot, engine running, engine just switched off, or cold is fine?
2. If the tube does not go down the dipstick what is another way I can get to the oil without draining it?
Can I remove the oil filter and extract some oil from there?
Or can I remove the oil cap and try to get some from the head?
3. The kit came with a 30cc syringe and a 100ml or so canister. Is 30cc enough for the lab or must I fill the canister?
2003 Mitsubishi Diamante 6G74 3.5L. 5 Speed auto. 160,000 miles. Shell Helix Ultra 5W40 at 6k OCI
Re: How to extract oil? [Re: Spetz] #4884383
10/01/18 09:48 AM
10/01/18 09:48 AM
Wet side WA
JohnnyJohnson Online content
JohnnyJohnson  Online Content
Wet side WA
I would say it would be best to have just turned to engine off so things haven't settled out and are suspended in the oil.
2004 Corolla 132848
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 75007
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: How to extract oil? [Re: Spetz] #4884390
10/01/18 09:59 AM
10/01/18 09:59 AM
Atlanta,GA
BMWTurboDzl Offline
BMWTurboDzl  Offline
Atlanta,GA
Engine warm not hot nor cold. Maybe sample an 30 mins or so after you've driven it. The idea is that any solids will remain uniformly distributed in the oil and not have settled at the bottom of the pan.
You could reach out to Blackstone Labs. They may have suggestions on how to sample.
435i
Re: How to extract oil? [Re: Spetz] #4884432
10/01/18 11:08 AM
10/01/18 11:08 AM
ON, Canada eh?
StevieC Online content
StevieC  Online Content
ON, Canada eh?
When I do sampling and not complete changes at the time of a UOA collection, I like to make sure the vehicle has been run somewhere like shopping etc. I return home, let the vehicle cool a little and then I send the tube on my collection pump down the dipstick tube. I have found that lubricating the outside of the tube with clean engine oil makes it go down the tube much easier. I always dump the first bit of extracted oil back into the engine via the oil cap in case there was residuals in the tube/pump from the last extraction. Then on the second extraction I pump this into my bottle to be sent to the lab.
'18 Caravan - 36k KM - AMSOIL SS 0w20, Fram Ultra, TC-W3 500:1
'06 Santa Fe - 535k KM (Retired)
There is no such thing as "lifetime" fluids! mad
Re: How to extract oil? [Re: Spetz] #4884445
10/01/18 11:22 AM
10/01/18 11:22 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
Sounds like the plan! /\ /\ /\
2019 VW Jetta S,6M OCI#0 4071mi-Castrol Edge Prof? VW508+OE Filter; '17 Subaru Crosstrek CVT OC#6 43467mi-Valvoline Adv 0w20 + SOA Filter
Re: How to extract oil? [Re: Spetz] #4884704
10/01/18 04:33 PM
10/01/18 04:33 PM
Danh Offline
Danh  Offline
Just one more small suggestion: Mark the extraction tubing at a point where it equals the length of the dipstick. This will ensure you extract oil from a good midpoint and don’t reach the bottom of the sump where crud could have settled and accumulated.
Re: How to extract oil? [Re: Spetz] #4884847
10/01/18 06:57 PM
10/01/18 06:57 PM
On the road Midwest
Ihatetochangeoil Offline
On the road Midwest
Answer per Blackstone: https://www.blackstone-labs.com/gas-sampling.php Answer per me: I take my samples from a hot, running engine; but I have bypass filters with a sampling petcock; it's pretty easy and mess free. I wear leather TIG welding gloves in case of accidental contact with hot engine parts. To sample from my son's car, (no petcock), I remove the oil filler cap (with the hot motor idling) and carefully insert the sampling tube into a "puddle" of oil in a low area cast into the cylinder head; it may take several "draws" and a few minutes to get enough oil for the sample bottle.
2. If the tube does not go down the dipstick what is another way I can get to the oil without draining it? Answer per me: You can also loosen the oil filter a little and catch some oil, I've done this with a clean spare glass beaker and then poured it into the sampling bottle, but I would NOT attempt this on a running engine!!! I let the engine run long enough to reach equilibrium temperature; chock, jack and support the car, then shut the engine down and immediately get my sample. Job 1 is to be very cautious, be safe, don't get burned. A splash in the face with hot oil is not funny; I wear safety glasses, a full face polycarbonate grinding shield and a leather welding jacket. Never been burned and don't plan on it. Who does?
3. The kit came with a 30cc syringe and a 100ml or so canister. Is 30cc enough for the lab or must I fill the canister? Answer: Blackstone says they need 3 oz; which works out to about 90 ml. https://www.conversion-metric.org/volume/ounce-to-milliliter
Re: How to extract oil? [Re: Spetz] #4884880
10/01/18 07:29 PM
10/01/18 07:29 PM
Texas
4WD Offline
4WD  Offline
Texas
For large industrial engines the sump is a no-no and samples are taken from the cooler loop (sample valve) …
Re: How to extract oil? [Re: Spetz] #4927464
11/18/18 08:49 AM
11/18/18 08:49 AM
San Antonio, TX
jorton Offline
jorton  Offline
San Antonio, TX
Do you think I can get a sample from the dipstick tube on a CVT? I think the tube makes a right angled turn at the attachment to the transmission.
"If everything seems under control, you're just not going fast enough."
- Mario Andretti
