I have four of these trucks, all share the same configuration and service schedule. They all have similar mileage and work loads.
2012 Ford F-250 SC, LB 4WD, gas engine.
One particular truck will not take fuel. Tried different pumps, stations, times of day, different levels of fuel in tank, engine on, engine off.
It's quite the ordeal re-fueling. The driver has to barely squeeze the trigger on the pump to allow the gas to trickle down the fuel neck. Holding the nozzle wide open, the gas will quickly fill the tube, spit back, and the nozzle automatically clicks off.
It seemed that the problem was "solved" by holding the nozzle 90 degrees but that could not be replicated consistently.
Crawling under the truck, the fill tube and vent appear to be serviceable and undamaged. Also, this problem started soon after the switch to winter blend fuel.
Downing this truck is not an option. Must wait for winter for major repairs. At this time, I consider it a time-consuming nuisance for the driver. The truck otherwise runs fine.
Any ideas? Recalls? TSB's I'm not aware of? Any one else have this problem?
