Originally Posted by Astro_Guy
It seems to me that most of my mowing occurs between 70 and 80 degrees, and snow blowing between 20 and 30 degrees. If those estimates are accurate, then my snow blower normally operates in temperatures 50 degrees cooler than my lawn tractor. 10w30 has worked just fine for the past four seasons in the lawn tractor, so I can't think of a reason to run a thicker oil in a snow blower running in much cooler temperatures. Even if the snow blower were stored in a well heated garage to overcome the starting problem, I can't see how it is ever going to run hot enough to need 15w40. Why not just run 5w30 like the manual says?
Never really gets up to temp, exactly where the 15/40 is beneficial.
