So...two years of UOAs. The first on Fuchs GT1 5w40, the second on Joe Gibbs DT40
Code
OIL 5w40 5w40
Fuchs DT40
MILES IN USE 3.5k 4.6k
MILES 83k 87K
SAMPLE TAKEN 10/25/17 10/28/18
ALUMINUM 2.8 3
CHROMIUM 2.1 2
IRON 12 8
COPPER 5.5 6
LEAD 1.3 1
TIN 1.2 1
MOLYBDENUM 2.6 398
NICKEL 0.2 0
MANGANESE 0 0
SILVER 0 0
TITANIUM 0 0
POTASSIUM 2.2 10
BORON 49 92
SILICON 3.8 16
SODIUM 1.5 24
CALCIUM 1800 1679
MAGNESIUM 16 6
PHOSPHORUS 705 893
ZINC 868 1051
BARIUM 0 1
FUEL
WATER
VIS 210F 12.6 12.9
BASE NUMBER NR 3.6
OXIDATION 39% 30 abs/cm
The first lab did not report on Base Number, and reported Oxidation as a percentage. The second lab gave a base number of 3.6, and Oxidation of 30 abs/cm, whatever that is.
I have seen VOAs for DT40, but they didn't include oxidation, and I understand you need to understand the start number of the oxidation to understand the number after usage.
Can anyone tell me more about my oxidation numbers or know the start numbers for DT40?
Code
OIL 5w40 5w40
Fuchs DT40
MILES 83k 87K
ALUMINUM 2.8 3
CHROMIUM 2.1 2
IRON 12 8
COPPER 5.5 6
LEAD 1.3 1
TIN 1.2 1
MOLYBDENUM 2.6 398
NICKEL 0.2 0
MANGANESE 0 0
SILVER 0 0
TITANIUM 0 0
POTASSIUM 2.2 10
BORON 49 92
SILICON 3.8 16
SODIUM 1.5 24
CALCIUM 1800 1679
MAGNESIUM 16 6
PHOSPHORUS 705 893
ZINC 868 1051
BARIUM 0 1
FUEL
WATER
VIS 210F 12.6 12.9
BASE NUMBER NR 3.6
