Originally Posted by dishdude
Originally Posted by KrisZ
Where did you find it? Would be good to know where approximately these things are installed. I would imagine near a power source, so somewhere near a fuse box would make sense.
Google search revealed they're usually hidden in the back by the package shelf and that's where this one was. The antenna wire was zip tied to an existing wire loom and ran down to the rocker panel behind trim. I expected it to be near a power source, but I was pleasantly surprised it was only battery powered. I didn't want some aftermarket accessory I wasn't using consuming power with the vehicle off.
Thanks!
Thanks!
