JamesTheBok Joined Apr 24, 2018 Messages 7 Location South Africa Nov 15, 2018 #1 Can I safely change from a 5W-30 ACEA C2 spec oil to a 5W-30 ACEA C1 spec oil? I'm thinking this will give a longer life to the DPF due to the lower ash content. Vehicle is a 2014 Fiat Doblo 1.6 Multijet (198A3000) turbo diesel. Last edited: Nov 15, 2018
Z zeng Joined Sep 1, 2015 Messages 2,876 Location Malaysia Nov 15, 2018 #2 I would think so. It's an upgrade in specification requirements, and probably costs more $$ .
E Elgouyo Joined Nov 10, 2017 Messages 8 Location France Nov 15, 2018 #3 C2 and C3 are mid-saps (0.5-0.8%). C1 and C4 are low saps ( C1 and C2 have 2.9 HTHS. C3 and C4 have 3.5 HTHS. Nevertheless, C1 seems to be the hardest to find. Maybe you can find a near 0.5~0.6% saps C2 oil ? Last edited: Nov 15, 2018
JamesTheBok Thread starter Joined Apr 24, 2018 Messages 7 Location South Africa Nov 15, 2018 #4 Was looking at Liqui-Moly Top Tec 4500. http://www.liqui-moly.eu/liqui-moly...&vcmstemplate=mobile&redirect=1. I can get it here in South Africa at a similar price to the 5W-30 C2 rated oils.
Kamele0N Joined Feb 9, 2015 Messages 3,850 Location Slovenia EU Nov 15, 2018 #5 JamesdontgobyTheBook this time...go C3/C4 way
JamesTheBok Thread starter Joined Apr 24, 2018 Messages 7 Location South Africa Nov 15, 2018 #6 Been doing some more research and must agree with you. C4 looks the way to go. Low SAPS, higher HTHS, and lower NOACK. The only one I can easily obtain here in South Africa is this Ravenol: https://www.ravenol.de/en/products/...s-hydrocrack-diesel-specific-5w-30.html. Looks to be pretty decent.
JamesTheBok Thread starter Joined Apr 24, 2018 Messages 7 Location South Africa Nov 15, 2018 #7 Been doing some more research and must agree with you. C4 looks the way to go. Low SAPS, higher HTHS, and lower NOACK. The only one I can easily obtain here in South Africa is this Ravenol: https://www.ravenol.de/en/products/...s-hydrocrack-diesel-specific-5w-30.html. Looks to be pretty decent.
S supercity Joined Jun 12, 2012 Messages 1,187 Location Australia Nov 16, 2018 #8 Castrol Edge Professional C1 5W-30 meets C1 and C2
Z zeng Joined Sep 1, 2015 Messages 2,876 Location Malaysia Nov 16, 2018 #9 Originally Posted by JamesTheBok Was looking at Liqui-Moly Top Tec 4500. http://www.liqui-moly.eu/liqui-moly...&vcmstemplate=mobile&redirect=1. I can get it here in South Africa at a similar price to the 5W-30 C2 rated oils. That's a good buy. KameleON provides more choices. Last edited: Nov 16, 2018
