So my plow truck is a 78 chevy k20. I think it has a 10si alternator. When plowing i usually have the heat on high, all lights on, and an overhead 12v plug in rotating beacon. Today i shut my truck off and it would not restart. It cranked over super slow like one turn over every second. I have not checked anything with a volt meter. The dash volt meter reads above 13v with everything running. The battery is about 5 years old. Does this sound like i am just drawing to much current from the battery? I would think the charging system could keep up considering the only thing thats being powered thats not normally is the 12v beacon light. Having the heat on and the lights on should not cause the battery to run down. The plow is run off a belt driven hydraulic pump so that is not drawing any electrical power.
