So my forge atmospheric bypass valve is having problems. Its on a 2012 cruze 1.4. It used my boost leak tester. After about 2-3 lbs of pressure it starts to come out of my bpv. Im tunned for 22 psi. I pressurized my motor to 25 psi and it leaked the whole time. Just a constant psssh out of the vent. Is the spring in it too weak? Im using the soft spring it came with. Also when im driving i can hear the bpv stay open then i slowly press the pedal more and i go into limp for underboost. The bpv is routed directly to the intake manifold. Do i have a bad bpv? Is the spring to weak? It has less than 400 miles on. It is lubed correctly and tq'd correctly.
