I have a 2017 Chrysler Pacifica and did an oil change yesterday.
I noticed the antifreeze reservoir was a little low so I topped it off.
I had a jug of G-05 HOAT and thought that it was the proper antifreeze to use.
Today I read that Chrysler switched to a OAT antifreeze and you should not mix them.
I probably only added a few cups of the G-05......do you think I will have any troubles from mixing the two ??
