Forums Migration
Please read this thread
Civic rear wheel bearing
by toad - 07/09/20 07:06 AM
Nokian Entyre C/S
by Robster - 07/09/20 06:00 AM
Corolla Cross
by wemay - 07/09/20 05:51 AM
Pennzoil strikes again with PDS (Euro 5W40)
by edyvw - 07/09/20 01:44 AM
Extra Load tires - Firmer ride?
by Spetz - 07/09/20 12:34 AM
make sure to use a software firewall
by 2004tdigls - 07/08/20 11:02 PM
Castrol 0w40 without LL-01 in BMW S63
by propellerhead78 - 07/08/20 09:59 PM
Automated key duplicators
by y_p_w - 07/08/20 09:59 PM
0W20 vs 5W20 base oils
by aquariuscsm - 07/08/20 09:39 PM
Shell Rotella T6 Multi Vehicle 5w30
by SummitX670 - 07/08/20 08:56 PM
Silicone rubber valve cover gaskets?
by Spetz - 07/08/20 07:59 PM
Back Up Camera
by Redright9 - 07/08/20 07:53 PM
Good Jackstands?
by 2015_PSD - 07/08/20 07:17 PM
Harbor Freight recalls more jack stands
by FordBroncoVWJeta - 07/08/20 07:11 PM
can a family of 4 use 34k gallons
by WhyMe - 07/08/20 05:26 PM
305 SBC Starter Grinding
by WA1DH - 07/08/20 05:19 PM
Ever hit a water meter with your riding mower?
by bchannell - 07/08/20 05:10 PM
Oil Recommendation 2020 GR Supra (Z4 har har)
by afree - 07/08/20 04:21 PM
Failing A/C compressor
by mb32 - 07/08/20 04:14 PM
Sledstorm1, Wishiwereaskibum, snowshew, Tenderness, SummitX670
71888 Registered Users
83 registered members (77Se7en, 86cutlass307, AlienBug, alarmguy, 55hambone, afree, 6 invisible), 1,215 guests, and 46 spiders.
Topics307,630
Posts5,314,544
Members71,888
E60 525i N52 AUS OIL #4922371 11/12/18 06:39 PM
Z
zx3rrider Offline OP
Z
TLDR what oil in AUS for an E60 with the N52
Hi Guys,
I'm currently driving a 2008 BMW 525i with the N52 engine down in Australia. I have been hearing and reading very conflicting stories on oil (What else is new xD) due to my hotter climate(-5.c - 50.c) and my harder driving conditions.
When i first got the car at 55,000km i was using Castrol Full Syn 0w40 as the car seemed to run smooth and be within good temps, however i found like my v6 Accord the castrol used to go down 1l per 1000km roughly(I realize that's within spec). So i switched to the Penrite HPR5 i had left over from my forester, the BMW is now at 85k. The car runs extremely quiet on this oil and after 5-6k it hasn't used anything on the dipstick. I was very happy with my choice until i was warned off Penrite by both the dealer and indy mechanic.
Has anyone got any good recommendations on oil or can tell me why my choice is bad? i seem to see allot of indy's in Aus using the German Castrol, Motul or Liquimoly. I usually change my own oil and filter every 6-8k or 6 months.
Thanks
ZX3R
P.S Was looking at going to https://liqui-moly.com.au/product/top-tec-4200-5w-30-2/ but its BMW LL-04 and it will Comply with LL-01?
Re: E60 525i N52 AUS OIL [Re: zx3rrider] #4922420 11/12/18 07:30 PM
O
oil_film_movies Offline
O
Originally Posted by zx3rrider
I'm currently driving a 2008 BMW 525i with the N52 engine down in Australia.....due to my hotter climate(-5.c - 50.c) and my harder driving conditions.
Hot weather, hard driving. I'll say get https://www.mobil.com/english-au/passenger-vehicle-lube/pds/glxxmobil-1-5w50 ... It has a lot of German spec approvals, not BMW, but that is sometimes a collaborative choice. Stout oil that would work, since it does have HTHS=4.4 in a full syn oil from an experienced company, Mobil.
Any 5w50 you find that has some tough German specs would be the best choice for an N52, hot, hard driving.
If you can't find 5w50 easily in a brand you want, then any 5w40 with German spec approvals should work about as well. The N52 does have a coolant-to-oil cooler to help with oil temperature getting too out of control when driving hard. If not the Mobil 5w50, there is https://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/EA96AC05824B089F80257F660024386F/$File/BPXE-A2A4GE.pdf as another option.
LL-04 will not comply with LL-01. LL-04 is low-mid saps, and LL-01 is full saps oil.
I'm not sure why you are hearing people say "not Penrite". If its a reputable company, and you see that is passes some difficult German specs (Porsche, Mercedes, BMW, any like that), then use it with confidence.
Re: E60 525i N52 AUS OIL [Re: zx3rrider] #4922467 11/12/18 08:02 PM
J
JAG Offline
J
Why did they warn you about Penrite? That reduction in oil consumption with it is huge. It’s doing something right in the rings and cylinders that Castrol 0W-40 wasn’t and it probably has nothing to do with volatility, since that Castrol oil has low volatility.
Re: E60 525i N52 AUS OIL [Re: oil_film_movies] #4922487 11/12/18 08:21 PM
Z
Z
I was thinking about Mobil, worst case is it ends up burning to fast for my taste like allot of these engines seem to do and i try something else? Is it bad to keep trying different oils?
My driving is usually 35% stop start, 55% highway and 10% spirited country roads, i really use the rev range as its a big car with a small engine. So by hard i mean im up in the revs allot, more aggressive then a usual driver haha.
Re: E60 525i N52 AUS OIL [Re: JAG] #4922490 11/12/18 08:22 PM
Z
Z
Yeah the Penrite seems to be very happy in allot of cars i put it in... plus its usually on sale haha. I'm just worried as i want this car to last the 300k my Accord did and its allot more complicated haha.
Re: E60 525i N52 AUS OIL [Re: zx3rrider] #4928291 11/18/18 10:22 PM
SR5 Offline
Hi Mate,
I've used a lot of Penrite oil, I think it's good stuff.
The HRP 5 (5W40) claims BMW LL-01, and it has significantly reduced your oil consumption, so I would just keep using it. It will be fine for your temperature range.
Here is a link to the Penrite HPR 5 web page
<Penrite HPR5>
The HPR5 oil carries a lot of good OEMs: A3/B4, BMW LL-01, MB 229.5, Porsche A40, VW 502/505.00, with a viscosity of KV100 = 14.4 cSt
The Castrol Edge 0W40 carries the same OEMs, but it's a thinner oil KV100 = 13.1 cSt.
So I think your car just consumes less oil when you run a thicker oil, which is not unusual and not much to worry about, just use the thicker stuff that meets your approvals.
Valvoline DuraBlend 10W40 SN & A3/B4 semi-synthetic + Valvoline V06 synblend media filter
Re: E60 525i N52 AUS OIL [Re: SR5] #4929389 11/19/18 07:59 PM
Z
Z
Thanks for the reply mate.
I was also looking at Mobil 1 0w40 and Catrol Edge 5w40, is the Penrite a 'better' oil for my conditions? I'm about to do a 4000km return trip so i really want the car to be happy with what is in it smile
I found the Castrol 0w40 to be allot quieter at cold startup.
Re: E60 525i N52 AUS OIL [Re: zx3rrider] #4929643 11/19/18 11:33 PM
SR5 Offline
Hi Mate,
All of those oils are top shelf, Castrol Edge 0w40, Castrol Edge 5W40, M1 0W40, Penrite HPR5 5W40 plus I would add Shell Helix Ultra 5W40 and Valvoline SynPower 0W40 to the list. All carry a big list of Euro OEM specs. I don't think any one is better than the other.
Me I would just buy on price unless I found one that worked better than the rest, then I would stick to that one.
As you already said about the Penrite "The car runs extremely quiet on this oil and after 5-6k it hasn't used anything on the dipstick."
Re: E60 525i N52 AUS OIL [Re: SR5] #4931951 11/22/18 07:44 AM
Z
Z
Got an awesome black Friday deal on the shell ultra will give it a try! Thanks mate.
Re: E60 525i N52 AUS OIL [Re: zx3rrider] #4932523 11/22/18 08:46 PM
J
JFAllen Offline
J
was on 50% sale at supercheap the other day wink Helix Ultra is a great product.
Re: E60 525i N52 AUS OIL [Re: zx3rrider] #4932724 11/23/18 04:59 AM
SR5 Offline
Yep SHU 5W40 is a great oil.
Re: E60 525i N52 AUS OIL [Re: zx3rrider] #5457328 06/18/20 10:08 PM
Z
Z
Been a while, the e60 is long gone and the SHU was a great oil in that motor(Burnt 500ml-1000ml every 3000km but was silent as a mouse) very happy with it thanks to SR5. I have moved onto a newer 5 series still with an N52 however the indy mechanic i used put LM Toptec 4200 in it 6500km ago (No oil burned!). I thought being an LL04 oil it wouldnt be the best idea in a gasoline car? How does the LM toptec 4200 5w30 compare to the SHU 5w-40 in terms of performance?
Thanks
ZX3R
Re: E60 525i N52 AUS OIL [Re: zx3rrider] #5457413 06/19/20 03:36 AM
B
Bjornviken Offline
B
Have had the same experience with Castrol Edge
