Megapulse VEE System
by toyota62 - 03/31/20 01:35 AM
If only I had more time...
by 14Accent - 03/31/20 12:34 AM
Pennzoil Ultra Platinum 0W-40 availability.
by LTZ10 - 03/30/20 11:01 PM
Brake Fluid testing - moisture & copper
by DIY4quality - 03/30/20 10:49 PM
My E46 with BMW Style 225M wheels
by SLO_Town - 03/30/20 10:49 PM
2019/2020 VW Jetta GLI
by TCU_Adam - 03/30/20 10:00 PM
Inner Core Oil Filter
by QuangTeo - 03/30/20 09:56 PM
245/65/R17
by KE7JFF - 03/30/20 09:42 PM
Replace fuel sending unit or just roll with it?
by cwilliamsws6 - 03/30/20 09:37 PM
lawn sprinkler troubleshooting
by Burt - 03/30/20 07:44 PM
Air conditioner in a toyota avalon
by ChrisSnowden - 03/30/20 06:11 PM
CV axle shaft vertical play?
by JHZR2 - 03/30/20 05:29 PM
This is how it's done!
by Mad_Hatter - 03/30/20 04:56 PM
Android to PC pictures?
by Eddie - 03/30/20 04:30 PM
Crazy fixes that worked
by IMSA_Racing_Fan - 03/30/20 01:39 PM
Cadillac CTS 4 AWD driveline care and feeding
by IMSA_Racing_Fan - 03/30/20 12:13 PM
Heaviest 5w-30 Synthetic?
by Propflux01 - 03/30/20 11:53 AM
Upgrade from HDD to SSD
by diyjake - 03/30/20 11:39 AM
Z08969, TCU_Adam, deaner1979, jdana24, KlenFrappe379
71061 Registered Users
29 registered members (AC1DD, Ammofirst, avi1777, 928, bachman, 14Accent, 4 invisible), 602 guests, and 15 spiders.
Topics303,497
Posts5,235,146
Members71,061
Interesting filtration test result #4917423 11/07/18 10:14 AM
B
Baveux Offline OP
B
Re: Interesting filtration test result [Re: Baveux] #4917461 11/07/18 10:54 AM
B
beanoil Offline
B
Interesting, thanks for the link.
Re: Interesting filtration test result [Re: Baveux] #4917475 11/07/18 11:13 AM
O
oil_film_movies Offline
O
That 1988 SAE paper has been cited a million times.
Its part of the reason why you see Fram Ultra recommended so much on here. The Ultra's depth filtering capability is unmatched.
Ultra: 99.5% 20 microns, 94% 10 microns, 80% 5 microns.
BTW, when you read about "clearances", its all true that some particles slip past parts inside, yet understand that boundary lubrication happens inside an engine on loaded surfaces and the distance between rubbing parts can go to very near zero, so that a 0.5 micron soot or sand particle can cause extra wear too.
Bottom line: the cleaner the oil, the better.
Re: Interesting filtration test result [Re: Baveux] #4917476 11/07/18 11:13 AM
A
Ablebody Offline
A
Re: Interesting filtration test result [Re: Baveux] #4917660 11/07/18 02:43 PM
L
Linctex Offline
L
I had all the bits and pieces to make a simple, basic, inexpensive "by-pass oil filter" system.
I know it isn't 99.9% at 5 microns, but every little bit helps
Re: Interesting filtration test result [Re: oil_film_movies] #4917668 11/07/18 02:54 PM
Z
ZeeOSix Offline
Z
+1 ... some people don't seem to understand that simple logic.
Re: Interesting filtration test result [Re: ZeeOSix] #4917671 11/07/18 03:00 PM
Malo83 Offline
Hooray for annual oil changes crackmeup
Re: Interesting filtration test result [Re: Baveux] #4917710 11/07/18 03:50 PM
Purpfox Offline
All about the clean, Last batch of m1 5w20 I tested was cleaner that the oem filtering system. which is good for the oil not for the truck lol
Certified Analyst ( by no means an expert Much to learn )
