Megapulse VEE System
by toyota62 - 03/31/20 01:35 AM
If only I had more time...
by 14Accent - 03/31/20 12:34 AM
Pennzoil Ultra Platinum 0W-40 availability.
by LTZ10 - 03/30/20 11:01 PM
Brake Fluid testing - moisture & copper
by DIY4quality - 03/30/20 10:49 PM
My E46 with BMW Style 225M wheels
by SLO_Town - 03/30/20 10:49 PM
2019/2020 VW Jetta GLI
by TCU_Adam - 03/30/20 10:00 PM
Inner Core Oil Filter
by QuangTeo - 03/30/20 09:56 PM
245/65/R17
by KE7JFF - 03/30/20 09:42 PM
Replace fuel sending unit or just roll with it?
by cwilliamsws6 - 03/30/20 09:37 PM
lawn sprinkler troubleshooting
by Burt - 03/30/20 07:44 PM
Air conditioner in a toyota avalon
by ChrisSnowden - 03/30/20 06:11 PM
CV axle shaft vertical play?
by JHZR2 - 03/30/20 05:29 PM
This is how it's done!
by Mad_Hatter - 03/30/20 04:56 PM
Android to PC pictures?
by Eddie - 03/30/20 04:30 PM
Crazy fixes that worked
by IMSA_Racing_Fan - 03/30/20 01:39 PM
Cadillac CTS 4 AWD driveline care and feeding
by IMSA_Racing_Fan - 03/30/20 12:13 PM
Heaviest 5w-30 Synthetic?
by Propflux01 - 03/30/20 11:53 AM
Upgrade from HDD to SSD
by diyjake - 03/30/20 11:39 AM
Z08969, TCU_Adam, deaner1979, jdana24, KlenFrappe379
71061 Registered Users
32 registered members (ajchien, 14Accent, avi1777, bachman, A_A_G, Bailes1992, 5 invisible), 748 guests, and 17 spiders.
Topics303,497
Posts5,235,129
Members71,061
What hydraulic filter has 3/4+16 threads #4917084 11/06/18 08:25 PM
A
Ablebody Offline OP
A
I'd like to add one to a filter mount I ordered to put in the return line from the cooler.
I'd like to find a good efficient hydraulic filter instead of an oil filter. I'm not real concerned with a bypass.
Thanks
Re: What hydraulic filter has 3/4+16 threads [Re: Ablebody] #4917132 11/06/18 09:19 PM
SubieRubyRoo Offline
Baldwin B2-HPG likely one of the better, more available filters that have very fine filtration and sturdy construction. Might not be a "hydraulic" filter but if this is for an engine it's a very good filter.
De omnibus dubitandum.
Re: What hydraulic filter has 3/4+16 threads [Re: SubieRubyRoo] #4917143 11/06/18 09:34 PM
A
Ablebody Offline OP
A
Ok I'll check it out. Thanks
Re: What hydraulic filter has 3/4+16 threads [Re: Ablebody] #4917152 11/06/18 09:43 PM
A
Ablebody Offline OP
A
Descriptions: High Performance Glass Full-Flow Lube Spin-on (Also Used as Hydraulic or Transmission)
Contains: Anti-Drainback Valve;8 PSID Front End By-Pass Valve
Fits: Antonio Carraro, Hagie, Hymac, Steyr-Daimler-Puch Equipment; Iveco, R.V.I. Trucks
Replaces: Allis Chalmers 7023700-0; Case A146696; Ford B7A-6714-A, C9NN-6714-A
Thread: 3/4-16
O.D.: 3 11/16 (93.7)
Length: 5 13/32 (137.3)
I. Gskt.: G381-A
UPC: 791440000025
It says also used as a hydraulic or transmissions filter.
Thanks again.
Do you know how to see the micron rating?
Re: What hydraulic filter has 3/4+16 threads [Re: Ablebody] #4917158 11/06/18 09:50 PM
L
Linctex Offline
L
Thanks
Many of them use the same element inside.
However, for the BEST - look at :
The Baldwin HPG series, or -10 filters
the Donaldson Synteq,
Fleetguard Stratopore
and Fram Ultra ( & also Royal Purple)
Will all be the best media
Re: What hydraulic filter has 3/4+16 threads [Re: Ablebody] #4917212 11/06/18 11:15 PM
L
Linctex Offline
L
These B2-HPG are really pretty good, I think they are around 2-5 microns nominal, and about 10-15 absolute.
Remember, a normal automatic trans filter is about 100 microns!!!!
Re: What hydraulic filter has 3/4+16 threads [Re: Ablebody] #4917228 11/07/18 12:23 AM
Cdn17Sport6MT Offline
Thanks
If you are plumbing it in-line, and not on a bypass basis, very tight filter media could be a problem, and could result in restriction or blockage of the oil stream that goes to the tank-cooler and then comes back into the transmission / transaxle. If memory serves, some of the ATF cooler streams are subsequently routed to a lube point... so other than an impaired cooling cct, you would also suffer lack of lubrication. Certainly, YMMV - but for me I would never configure an ATF additional filter in line. The comment above about OEM filters being as much as 100 micron - they are, for a reason.
OTOH, some folks here have plumbed in tight filter media, in line, but also have plumbed in a differential pressure indicator (gauge) - and have very closely watched for media load-up.
Why would you risk it, if bypass arrangement works exceedingly well.
Mazda6 GX (Sport in the 'States), 6MT, 2017
Moto Guzzi 850 T5 (Euro version), 1985
Honda Civic Si (EX 2 dr. in the 'States), A/T, 1997
Toyota Camry CE, 5MT, 1999
VW (Type2) Kombi, 4MT, 1979
Re: What hydraulic filter has 3/4+16 threads [Re: Ablebody] #4917254 11/07/18 02:38 AM
B
BlakeB Offline
B
I have a Napa 1269 on my Tacoma.
FleetFilter-51269
Napa 1269 / Wix 51269
If I don’t change my mind, I’m gonna put a Fram Ultra XG8A on it next. They’re supposed to be something like 99%+ at 20 microns and 80% at 5 microns.
The 1269 is 10 nominal, beta ratio of 2/20=5/17.
I’ve had the remote filter/1269 on my Tacoma for 6 years with no issues. These filters have an 8 psi bypass if anybody is worried about that.
Re: What hydraulic filter has 3/4+16 threads [Re: Cdn17Sport6MT] #4917257 11/07/18 03:09 AM
L
Linctex Offline
L
No..... You have a better chance of getting killed by lightning. Yes, seriously.
The Baldwin BT839-10 filter on my trans line has a flow rating of somewhere close to 20 GPM.....
That filter will last 300,000 miles at that rate on my F150, and still NEVER even get close to being a restriction.
Same with the XG-8A and other similar synthetic media filters - right around 20 GPM in that size.
............and - they never plug up. I cut one open that was on an Allison trans for 80,000 - it had almost nothing in it
Re: What hydraulic filter has 3/4+16 threads [Re: Ablebody] #4918301 11/08/18 10:57 AM
It's amazing what synthetic fluids can do when they aren't contaminated by combustion byproducts....
