Several months ago I did a drain and fill in my 5.9l cummins 48re transmission. I could see on the dipstick that the fluid was still not as clean as I'd like. I bought a 1/2" magnafine filter after talking with their tech support. I went to install the filter today and discovered the inside diameter of the hose going to and from the cooler is 5/8". Of course I had to cut the old line before i found out i had the wrong sized inline filter. So now I'm left replacing the hose and still not installing the new filter. Should i just install a remote filter instead? I can find a kit for about 50 bucks. Thoughts?
