JHZR2
Staff member
My accord hybrid does 10-15k miles per oci. This time it was 10500 when It hit 10%. As it's a hybrid, it starts and stops the engine continuously, under load, on the highway, etc.
This is the (honeywell or gram)? Cardboard endcap version. No concerns whatsoever with that construction, given that it has stayed strong, stable, and flat. My cartridge filters get wavier with compressing into its bore, so the media waviness is not a concern to me.
M1 EP 0w-20 has always been used on this vehicle.
Probably fine for 2yr/20-25k miles. I do skip filter changes on the van if and only if I don't change the oil brand/type. It's much cleaner/easier on this car. One of the best spin on designs I've encountered.
I changed in a M1 filter. It did have a tiny bit of surface rust fwiw.
