Originally Posted by ragtoplvr
I know a woman with in excess of 400K on an aluminum cylinder BMW motorcycle and has never had rings. The engine has been split to replace cam chain guides, just the guides not the chain. It has also had rod bearings. That is it, 400K sMiles. and (gasp) all on conventional oil, no synthetic.
They just do not wear.
I also had an aluminum bore Briggs and Stratton 11 HP last for 21 years, mowing 3 acres, never even had a spark plug! Used 10W40 and I did clean out the fins on the cylinder every 2 years, I think that made more difference than anything. It was just starting to use oil, I was considering an new engine since the carb butterfly was so worn it would no longer idle, when transmission failed again. No parts since Husqvarna bought Dixon, the deck was so thin I had to reinforce where the bade spindles attached. It was time for a new one. I do not like hydrostatic drives nearly as well as the Dixon friction system. A hydrostat locks the wheel when in the neutral position, the friction neutral was coast. I mark the yard a lot more with hydrostat.
Rod
That's encouraging to hear your 11 HP aluminum bore Briggs & Stratton engine lasted that long. I have a Briggs & Stratton 5500 Watt generator with the 342 CI aluminum bore engine and I'm a bit concerned with it's longevity. I'm using the Briggs & Stratton synthetic 5W-30 oil, I got it for $4.30/qt. I did 3 short run changes to get the "glitter" out. I just did another OC after 20 hours and there was no glitter in the oil. Though there was A very faint streak in the oil. I saw no more metal as seen previously. I think I'll keep the OC to around 20-25 run hours instead of 50 max that's in the owner's manual. I'll also keep using a synthetic oil, not the B&S oil as that's now around $14/qt
. It runs really great, makes clean power and is fairly "economical" for it's size. I'd like to keep it for a long time. I exercise it with a 3,000 watt balanced load every 3 months for an hour.
Whimsey
