Working on a old kerosene torpedo heater. Has the blower motor in the back that appears to also have a small air pump built into it. The air pump goes into the nozzle assembly where it is used as a Venturi effect to pump kerosene from the tank and blow it out the nozzle.
Put a auto vac/pressure gauge on the hose from the air pump and I see about 1 PSI.
Does 1 PSI sound right. Or do I misunderstand how it works?
