Pentosin ATF 134 FE (Blue)
CA
Pentosin is now offering a MB approved fluid for the NAG II+ 722.9 7-speed automatic transmissions. Basically, it is for most 722.9 transmissions built after 7/2010 and have the two oval dimples in the oil pan.
http://www.pentosin.net/specsheets/Transmission Fluid_ATF 134 FE_2017_COLOR.pdf
https://m.autoserviceprofessional.c...in-transmission-fluids-for-mercedes-benz
The cost is about 1/2 of the dealer fluid.
I used 8.5 liters today on a C250 (pan drop plus torque converter drain) and can confirm that it looks, smells and shifts like the dealer fluid.
Great!
I've got 12 liters of Pentosin to go in my NAG-1 this month. Glad to hear that you're pleased with it.
Wow that is expensive! And the dealer is TWICE that?
Valvoline also says it's ok to use Maxlife on 236.15, except in California
Here is their PI sheet
Originally Posted by Hammehead
18 cst at 40C and VI of 160. What´s the ~ 100C viscosity?
4.2 cst.
https://www.mobil.com/English-GB/Passenger-Vehicle-Lube/pds/GLXXMobil-ATF-134-FE
Originally Posted by Wolf359
Did you have a shell distributor near you? There's also Shell ATF 134 FE and that's usually sold by the case of 12 quarts.
https://www.shell.us/business-customers/lubricants-for-business/lubricants-distributor-locator.html
Last time I asked, they said it was around $65 a case. How much was the Pentosin?
Pentosin was about $12/L from a local distributor. I have priced out the Shell product, but the only distributor is 60 mile away and I needed the fluid same day.
