Towing with MMO
Originally Posted by talest
Originally Posted by demarpaint
Originally Posted by caprice_2nv
I actually put it down the cylinders of the gm 5.3 I plan on putting in my Caprice one day. It has unknown maintenance history and the oil was very dark when I bought it. I'm hoping it soaking into the pistons will clean out the ring packs over the years or two it sits on the engine stand. (actually I think it's been almost 2 years now).I turn it by hand every now and then.
Have you topped up the cylinders since you first added it? If not It might be a good idea to do so.
Slow piston soak, would you use something other than MMO or is MMO (kerosene) ideal for that?
I considered seafoam also but I went with MMO. I do need to add more I just haven't been thinking about it lately. The engine swap is going to be much more long term than I had hoped. I'm open to suggestions for something readily available besides MMO or seafoam though.
