HELP something went down my dipstick hole
Just watched a video of an ATF change on a V6 Accord, 2003-2007, and it does have the fill port like our Odyssey. Why not use instead of the dipstick ? Either method works though. That fill port fastener will be tight too ! You will need a fairly long extension on a breaker bar in order to crack it loose.
My brothers Civic 97 was also the same, the fill hole was burried right at the bottom next to the wheel cover. It has a rubber plug and remember his didn't even have it, the ATF hole was exposed to water dirt and all kinds of things. Idiotic design, how much would it cost Honda to extend it further up. Classic shortcuts in engg
