I just realized my flasher light knob is broken off. Any ideas as how to fix and or replace it? If you push the stub that's left under the steering sleeve the flashers work. I tried taking photos but its hard to see what I am speaking about.
It is merely threaded into the switch in the column. If you have broken it off right at the switch and you can't get a needle nose pliers on the remaining threaded stud, then you will be faced with trying to extract it using the usual methods (EZ out etc.). Try not to damage the threads on the switch of course.
