Chery A520 2.0 L Transmisstion Oil
by Omar_Eltahan - 01/20/20 02:38 AM
castrol 5w30 c3 for an LS?
by neo3 - 01/19/20 11:32 PM
Windows 10 Upgrade Guide
by OVERKILL - 01/19/20 09:59 PM
FCA and Foxconn partner on EV's
by OVERKILL - 01/19/20 08:55 PM
IIHS Crash pics of Full Size Trucks
by kstanf150 - 01/19/20 08:15 PM
Are Engine Splash Guards Really Needed?
by Mr_Luke - 01/19/20 08:14 PM
supertec cartridge filters
by super20dan - 01/19/20 06:17 PM
More Valvoline on rollback at WM
by jayjr1105 - 01/19/20 06:13 PM
Crossed poles on jumper cables
by 3Aone - 01/19/20 05:33 PM
Napa Gold 7060 7.5K miles
by KenshinHimura - 01/19/20 05:09 PM
Can you move a car with the starter?
by atikovi - 01/19/20 04:49 PM
Leaf spring advice.
by mpack88 - 01/19/20 02:19 PM
Detroit 4-53T swap update.
by A310 - 01/19/20 12:54 PM
Wiper arm tension...
by Loogie - 01/19/20 12:26 PM
Changing Battery
by Char Baby - 01/19/20 12:16 PM
UOA shelf life
by STIcandy - 01/19/20 12:02 PM
Harry_Seaward, MrH1325, Thetarmac, lbstyling, tanpw
70483 Registered Users
56 registered members (AurionX2, AlienBug, 2015_PSD, Astro_Guy, Arrechera, 67ZL1, 6 invisible), 1,532 guests, and 35 spiders.
Topics300,336
Posts5,173,613
Members70,483
Most Online3,825
Jan 19th, 2020
Page 3 of 3 1 2 3
Re: Pre-filling filters effect on first startup [Re: VeryNoisyPoet] #4812045 07/12/18 07:51 AM
G
goodtimes Offline
G
Filters that point base down will drain out the center area over time, like the v6 Camry we used to have. Depending on the main baring clearances I suppose as I would drain oil overnight to have a dripless oil filter removal. Every overnight start was a little bit of a dry start on that car, but light went out fast.
What about the oil pump relief valve, if oil is too thick the back pressure could be enough to open it, reducing flow.
Re: Pre-filling filters effect on first startup [Re: VeryNoisyPoet] #4812179 07/12/18 10:17 AM
T
Triple_Se7en Online Content
Online Content
T
Personally, I would never buy a vehicle with a filter thread that's on the bottom of the engine oil filter housing.
Other things that stop me cold at dealers, is (one exmaple of many)....when I raise the hood and can't stick my hands in the engine, to occasionally do maintenance. My daughter's 2008 Pacifica is the worst I've ever encountered.
19' Hyundai Santa Fe 2.4 GDI - Valv Adv. 5w30 / OEM Oil Filter / 6oz Liqui-Moly
20' Kia Soul X-Line 2.0 Multi-port / Pennzoil Gold 5W30 / OEM filter
04' Colorado 3.5 Castrol Edge 0W40 / K&N filter
Re: Pre-filling filters effect on first startup [Re: VeryNoisyPoet] #4909349 10/29/18 12:33 PM
V
VeryNoisyPoet Offline OP
V
Changed oil a few days ago and did not add any oil to filter before installing besides a few drops on the gasket. Again filled with Valvoline 10w-30 Synthetic with Maxlife Technology and used a Mann W917 filter. Similar ambient temperatures. Similar vehicle angle.
Compare to the first video where I did prefill the filter before installing:
1998 V70 GLT / 202k miles [10w-30 Valvoline Syn w/ Maxlife Tech + Mann W917 filter]
"Use yah blinkah!"
"Be nice. The alternative involves an air horn and 7000 lumens of high beam."
Re: Pre-filling filters effect on first startup [Re: VeryNoisyPoet] #4909351 10/29/18 12:38 PM
Z
ZeeOSix Offline
Z
I see about 1 second difference to achieve oil pressure.
Re: Pre-filling filters effect on first startup [Re: VeryNoisyPoet] #4909451 10/29/18 02:27 PM
W
WellOiled Offline
W
Thanks for the videos. Using a kitchen timer, I get about a 2 second difference. Using measured pressure is certainly better than listening for rattle.
When listening for rattle, if the out going oil is in rough shape (I.E. low viscosity) I notice more startup rattle when not filling the oil filter. If the out going oil is in good shape, I don't notice any startup rattle when not filling the oil filter.
VeryNoisyPoet - good post.
Mazda 6
Factory fill
Re: Pre-filling filters effect on first startup [Re: VeryNoisyPoet] #4909568 10/29/18 05:01 PM
T
Online Content
T
Our ears are a better / truer method to troubleshoot cold startup noise, over-that of a gauge reading on your dashboard.
Re: Pre-filling filters effect on first startup [Re: VeryNoisyPoet] #4909654 10/29/18 07:10 PM
W
WellOiled Offline
W
Triple_Se7en - I agree with that.
Mazda 6
Factory fill
Re: Pre-filling filters effect on first startup [Re: Triple_Se7en] #4909720 10/29/18 09:09 PM
V
V
This test was only looking at time to build pressure. Maybe next time I can also try to record any startup noise and edit the videos together
My engine doesn't noticeably rattle or clatter on a dry start. Maybe a slightly noisier valvetrain because hydraulic lifters without pressure but otherwise well behaved. Then again I haven't had my head down under the car immediately after first startup and I might notice more bottom end noise there.
"Use yah blinkah!"
Re: Pre-filling filters effect on first startup [Re: VeryNoisyPoet] #4909739 10/29/18 09:37 PM
K
kmrcstintn Offline
K
the Patriot has a vertical mounted filter on the bottom of the engine; the Buddy scooter has a horizontally mounted filter on the bottom of the engine casing; I fill both of these filters, allow the oil to soak thru the filter mefia and allow excess to drain for a few seconds before mounting (to prevent spillage)...while not completely filled there is volume inside to reduce the time of the first dry start after oil changes; the V Star motorcycle uses a horizontally mounted internal cartridge filter and presoaking it makes a mess so it goes in dry...
'15 Jeep Patriot Sport (2.4L 4-cyl), '13 Genuine Buddy 125 (125cc air-cooled thumper), '14 Yamaha V Star 250 (250cc air cooled v-twin)
Re: Pre-filling filters effect on first startup [Re: ZeeOSix] #4910386 10/30/18 06:09 PM
L
Linctex Offline
L
Originally Posted by ZeeOSix
If the filter was bone dry, it will probably take 4~5 seconds instead of 2 second to reach full pressure.
That's the exact same numbers/times I get with my 4.6 liter F150
Page 3 of 3 1 2 3
